4 GB Corsair Dominator PC2 8500 DDR2 10066 running at 800 MHZ?
Currently Active Users: 1533
Discussions: 200,509, Posts: 2,374,401, Members: 245,831
Old February 15th, 2008, 08:01 PM   Digg it!   #1 (permalink)
Lasher13's Avatar
Question
I have a dell XPS720 originally it had 2 GB of DDR2 1066 PC2-8500 RAM that ran at 1066MHZ and than I bought 2 more gigs and installed them, and I have to use third party programs like Rivatuner to tweak my system becuase I have no bios support, and I noticed my 4 GB's of Corsair Dominator PC2-8500 C5 10066 MHZ are running at 800 MHZ. So I know my computers only recognizing them as DDR2 800. Is there any kind of program that would let me change the timings and mess around with its voltages?
Lasher13 is offline   Reply With Quote
Old February 15th, 2008, 09:16 PM     #2 (permalink)
Prince Lalijama's Avatar
Send a message via MSN to Prince Lalijama
NVIDIA Ntune might do it. Has an option for memory, try it I guess. I don't have much experience at all with it though.
I'm PL, I've come to suck all the intelligence out of this thread.
Prince Lalijama is offline   Reply With Quote
Old February 15th, 2008, 09:38 PM     #3 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
If ntune doesn't work you might try memset or systool systool is a bit old so not likely going to work but who knows.
You might also try resetting the bios to see if it picks up the memory correctly. What if any settings does it have?
Linus Torvalds
RicheemxX is offline   Reply With Quote
Old February 16th, 2008, 04:01 AM     #4 (permalink)
Lasher13's Avatar
In the bios settings this is what I have
I have
Performance(tab)
Multiple CPU Core: OFF or ON set to on
Advanced: Performance Application support ON or OFF I highlighted the on option
in this section the processor Clock speed 2.40GHZ is highlighted but it wont let me change it.
Memory CMD Rate: Auto, 1T, or 2T Auto is highlighted, After reading your post I changed it to 1T and ended up resetting my CMOS. Still picks up my ram at 800Mhz
C1E Support: On or OFF mines on
SpeedStep: off <-----what is that?
Virtualization: off<----again????
EPP/SLI: on or off --- I set this on from off it sounded good when i read it
HDD Accoustic Mode: Bypass,Quiet, Suggested, or performance, Mines on bypass
Power Management: Ac recovery Off
Auto Power on: off
Auto Power time 12:00 AM
Suspend Mode: S3 or S1 mines S3
Maintenence: Serivice Tag, SERR Message, Load Defualts
Event Log: Post Error Memory size different, Memory Size Decreased
Fast Boot
Numlock Key
Post Hotkeys
keyboard errors
Onboard devices
security
system information
Drives
Well everything I've tried wont let me set the CAS latency to 4 for some reason.
Old February 17th, 2008, 12:58 PM     #5 (permalink)
dr_roberts49's Avatar
Speedstep is a process of the Intel duel cores.
Robert
"The philosphy of one century is the common sense of the next"
dr_roberts49 is offline   Reply With Quote
Old February 17th, 2008, 09:37 PM     #6 (permalink)
Lasher13's Avatar
I wonder what would happen when I turn it on though, would it make the CPU go faster? I'm scared to try it becuase the last thing I messed with in my bios left me stranded resetting the CMOS.
Old February 17th, 2008, 09:50 PM     #7 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Speedstep basically turns down your CPU when the system isn't under load. Like instead of running @2.4Ghz or whatever it is stock, it will turn it down to like 1.5Ghz or so, to kill heat and power consumption.
You can have it off or on, I personally have it shut off. It messes with overclocks.
I'd have this on also.
You need to leave that at 2T. There is no way your RAM will run 1T @800Mhz.
OFF
On
Basically, set it to performance, or leave it at bypass.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old February 17th, 2008, 09:58 PM     #8 (permalink)
Fur ballin
Sixpac_XP's Avatar
Whatever you do, don't use Ntune. Its junk.
Tune everything in the bios only.
--- Standby to receive our transmission ---
Sixpac_XP is offline   Reply With Quote
Old February 23rd, 2009, 06:32 PM     #9 (permalink)
1066 reply
Hi i have these ram and have no probs but the top speed is at overclock stats. with out its just 800mhz.
sidearm7 is offline   Reply With Quote
Old April 8th, 2009, 12:40 PM     #10 (permalink)
Hi,
Not sure if you've solved this yet, but I'll throw in my tuppence.
I had a similar problem. By default, the mobo reads the SPD information from the Corsairs, and this tells the motherboard that they are 800Mhz sticks. However, there is EPP information there too, which will tell the motherboard to run them at 1066. You need to tell the mobo to read this instead of the SPD.
In my case, this meant an option in the BIOS called Enable EPP Support, or something like that. I don't know what it will say in yours, but you need to look for something to do with EPP.
This should sort you out, if the problem is the same as mine, and you won't need to fiddle about with anything else.
Hope this helps.
moomintroll is offline   Reply With Quote
HELP..pc2 5300 on pc2 4200 laptop jcavz24x Processors, Memory, and Overclocking 2 February 9th, 2008 11:43 AM
HELP! Problem upgrading ram from 512mb ddr2 to 1gb ddr2 dabooj Processors, Memory, and Overclocking 2 January 21st, 2008 08:57 PM
Burnout Dominator (PS2) Review RobRich Game News Discussion 0 April 22nd, 2007 01:26 AM
Corsair TWIN2X2048-8500C5 DDR2-1066 Memory Review RobRich Tech News Discussion 0 May 30th, 2006 09:10 PM
Anyone running XP with Radeon 8500? J'rd Technical Support 16 December 1st, 2002 05:45 PM
Is It Just Me? (1635)
Review My Build (5)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
windows 7 retail and rtm (1)
I SELL GOOD STUFFS CCS TRACK BANK LOG.. (0)
sell cvv us-uk-eu-au...very good. who.. (0)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
