Ram Problem
Currently Active Users: 2685
Discussions: 200,965, Posts: 2,379,621, Members: 246,332
Old April 17th, 2008, 12:41 PM   Digg it!   #1 (permalink)
Ram Problem
I have a new build and i put 4 gigs of ram in it but i think all 4 gigs arent being red. when i go to my pc properties it says this
Intel(R) Core(TM)2 Quad CPU
q6600 @ 2.40GHz
2.40 GHz, 2.00 GB of RAM
if im reading this correctly the computer is only reading half my ram, i have windows xp and sp3
can ne1 help solve the problem?
xeneize368 is offline   Reply With Quote
Old April 17th, 2008, 12:46 PM     #2 (permalink)
Ride 'em Cowboy
Guessing you know that a 32 bit operating system maxes out at about 3.2 gigs...Meaning it can't use 4 gigs...
Have you tried the ram sticks two at a time and or any other combination?
Have you hugged your kid today??
Steve R Jones is online now   Reply With Quote
Old April 17th, 2008, 12:57 PM     #3 (permalink)
i have 2 2gig ram sticks, so right now its only reading 1, so it wont even read a part of my 2nd ram gig?
Old April 17th, 2008, 12:57 PM     #4 (permalink)
im getting a 64 bit one in a few weeks but i put the 32 one in so i can use my new build until then
another question, is the 2.40GHz ok or is that low?
Old April 17th, 2008, 02:42 PM     #5 (permalink)
ne help?
Old April 17th, 2008, 03:07 PM     #6 (permalink)
Ride 'em Cowboy
Which mobo do you have?
Maybe it has a max of one meg of ram per slot...
Old April 17th, 2008, 03:16 PM     #7 (permalink)
Gig rather.
Watch your POST screen and you can tell if all of that ram is being detected. You can also pause the POST screen with pause/break.
Although Steve is correct in that a 32 bit os cannot utilize that much ram you should be able to discover in your bios or on that post screen what is being detected.
DoubleK is offline   Reply With Quote
Old April 17th, 2008, 03:36 PM     #8 (permalink)
i have an xfx 680i mobo, i mean the ppl that sold it to me wouldve known if it wasnt compatible with that much ram and wouldve told me how do i look at my post screen?
Old April 17th, 2008, 04:07 PM     #9 (permalink)
Super F@D Folder
your post screen is the screen that comes up when you first hit the power button. The amount of ram should scroll by. There's also a message that says "hit f1 for setup". They key may vary (f1, esc, del..) but the message should say something like that. Hitting that key should take you to the bios where you can get the info as well!
Old April 17th, 2008, 04:15 PM     #10 (permalink)
im not gonna mess around with it for now, im getting a 64bit in a few weeks, thnx for all ur help though u guys should check out the thread called audio problem =]
problem with RAM mp3 ash Technical Support 15 January 7th, 2006 01:44 PM
RAM Problem localboy2332 General Tech Discussion 8 February 17th, 2003 08:58 PM
Ram problem iNeb Technical Support 3 December 25th, 2002 10:00 PM
ram problem- help! ecvtony Technical Support 6 July 24th, 2002 12:53 AM
Is It Just Me? (3006)
Forty-six years ago today (5)
Laptop with wireless problem. (11)
Internet Lost (5)
windows vista security holes (14)
Open With ..... Win7 (2)
Internet Lost (5)
NO GAS (0)
Help getting around port 80 for camer.. (3)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
