Thread: UDRAM and SDRAM (SAME or NOT?)
May 16th, 2008, 08:33 PM #1Junior Member
- May 2008
- 1
im just starting learning in troubleshooting im upgrading my 128mb memory card into 512mb. my problem is that when i looked at in the slot it labeled UDRAM. whats UDRAM actually? im searching it on the web on found no answer inly SDRAM always appear in my search.
my memory card has a specs of KVR133X64C3/128 3.3v and as i search for for this on the net i found out that this is a 128 MB PC133 SDRAM (KVR133X64C3/128).
is UDRAM and SDRAM the same?
please help
May 16th, 2008, 10:19 PM #2
From what I have seen on the 'net, it seems that UDRAM was used on older P2 systems. It is a different type of memory than SDRAM. From what I can gather, SDRAM modules will work in UDRAM slots, but they are a bit longer and the locking tabs at the ends of the slots don't latch correctly.
Is PC-100 SDRAM compatible with PC-133 SDRAM?
By holdenskickfords in forum Technical SupportReplies: 12Last Post: August 19th, 2010, 12:29 AM -
100mhz 128MB SDRAM or 133Mhz 64mb SDRAM?
By RickyOyola in forum Processors, Memory, and OverclockingReplies: 7Last Post: December 23rd, 2005, 07:00 PM -
UDRAM
By Cruez in forum General Tech DiscussionReplies: 5Last Post: November 3rd, 2005, 11:10 PM
Implying a knife, ball bat, cast-iron pan, taser, or running the hell away would not have also been effective. She had the means, just not the intelligence to utilize her surroundings to her...
Do YOU think having a gun would...
