July 25th, 2008, 02:01 AM
| Reaper
Better Deal, still a great power supply: Newegg.com - CORSAIR CMPSU-750TX 750W ATX12V / EPS12V Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC - Power Supplies
as far a 800 vs 1066 goes, you can adjust the memory multiplier to fit almost any RAM speed at the frequencies you will see, so it does not really matter. I personally have not seen much performance difference between 1066 and 800, so you should not be dissapointed with whatever set you choose, and 8 GB is a little overkill IMO. I hope you're using a 64-bit OS. |
