Processor bus speed and changing CPU speed.  | |
October 23rd, 2008, 02:11 PM
Hi,
Sorry if I am posting where there is already a thread created about this topic but I had a look and couldn't find any. I am having problems, well not problems because the CPU works but more issues with changing the speed. I have just installed AMD Athlon XP 3000+ processor i upgraded from a AMD Athlon XP 2000+ however the changes in GHz has barely changed. Have went from about 1.7GHz to 1.735. When I looked to up the speed in the BIOS to above 2.1 GHz (the highest setting) it said i had to have increased the Bus speed to 333Mhz or above and i could not located this.
Help would be great if you could tell me if it is actually a lot faster even though there hasn't been much of a ghz increase or if i should and can up the speed to 2.1 ghz.
thanks. |
October 23rd, 2008, 05:01 PM
| | Ride 'em Cowboy
What is the make and model number of your mobo?
__________________ Have you hugged your kid today?? |
October 23rd, 2008, 05:06 PM
Motherboard Name: Asus A7V333
Chip Set: KT333
If you want more information I have quite a bit on the motherboard. Hope I can increase the speed because if not I have bought a CPU which technically is 10 models up from the previous but I am getting pretty much the same output!  |
October 24th, 2008, 06:34 AM
| | Ride 'em Cowboy
Specifications
- CPU
Supports AMD Athlon XP 1500+ ~ 2100+ @ 266MHz FSB
Supports AMD Athlon 700MHz ~ 1.4GHz @ 200MHz FSB
Supports AMD Athlon 1GHz ~ 1.4GHz @ 266MHz FSB
Supports AMD Duron 600 ~ 1.2GHz @ 200MHz FSB ASUS A7V333 Motherboard Review :: TweakTown
Doesn't look like the AMD Athlon XP 3000+ is supported. |
October 24th, 2008, 06:46 AM
| | Super Stealthy Moderator
There are a few bios updates on the ASUS site with support for faster CPUs so it might support the 3000+. Looking at the manual it shows you have dip switches for changing the FSB. I'd guess the 3000+ is a 333fsb CPU so you'd beed to switch the switches to change the FSB to 166mhz. http://dlsvr.asus.com/pub/ASUS/mb/so...010_a7v333.pdf
In the bios, advanced tab, if you have the cpu speed set to manual, then you can adjust the speeds there. The option would be cpu/pci frequency. You'd up it to 166/whatever
Linus Torvalds
October 24th, 2008, 09:21 AM
Ah so in the Bios I don't need to change it to '333mhz' I change it to 166 and that corresponds to 333 like it sort of multiples? Or will there actually be an option of '333'.
And to Steve the motherboard does support it I had a look before I bought it and the 3000+ was the very last type. Seems to be working now as I am using the computer it is installed on.
thanks again all
also to add- in the manual in the last post I have found the jumperfree and sysclk dip switches and all the combinations they should be in for different speeds. Would I set it to 166 then it would be multiplied by the Frequency Multiple?
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Need help chosing memory speed vs FSB, CPU speed, etc. | Zoltar | Processors, Memory, and Overclocking | 0 | September 21st, 2008 08:44 PM | | CPU-Z not showing Bus Speed | rylenolflu | Applications and Operating Systems | 1 | January 6th, 2008 09:11 AM | | CPU bus speed | krishcanag | Processors, Memory, and Overclocking | 3 | December 31st, 2007 01:15 PM | | CPU bus speed... | Rostock | Processors, Memory, and Overclocking | 3 | January 5th, 2006 01:16 PM | | Bus speed for processor? | Elvaandragoon | Technical Support | 6 | November 4th, 2003 04:27 PM | |
