Join TechIMO for Free!
Thread Tools
Currently Active Users: 1765
Discussions: 188,468, Posts: 2,244,153, Members: 232,718
Old November 3rd, 2008, 04:13 PM   Digg it!   #1 (permalink)
24+4 pin or 24+8 pin?
Here's the board
Newegg.com - ASRock A780GXE/128M AM2+/AM2 AMD 780G ATX AMD Motherboard - AMD Motherboards
I notice that there is a spot for an additional 8 pin for power. Will a 24+4 pin PS work with this or must it have the 24+8?
Thanks in advance.
wambulance is offline   Reply With Quote
Old November 3rd, 2008, 06:18 PM     #2 (permalink)
ShyguyXPC's Avatar
24+4 should work fine, notice the other 4 pins are capped off?
from what I understand the extra 4 pins are more or less for higher end CPU's to give more power to. or so I was told... so depending on the CPU you might or might now want to use it...
but it should still be fine with the 24+4 pin PSU's.
Old November 3rd, 2008, 08:33 PM     #3 (permalink)
Ok, so I might or might not need it depending on CPU?
I appreciate the response but I'm still at square one.
Old November 4th, 2008, 09:38 AM     #4 (permalink)
This might get you out of square one... lol
6" Black Sleeved P4 4-pin to 8-pin EPS Cable Adapter
I've used it on a RioWorks dual Opteron board with no issues...
At $6.99, it's definitely cheaper than buying a power supply with the 8 pin connector...
dsmous is offline   Reply With Quote
Old November 4th, 2008, 10:33 AM     #5 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
If you don't use an Opeteron, and just use a Phenom/Athlon X2, then you should be fine with the 4 pin.
http://www.ubuntu.com
Old November 6th, 2008, 12:18 AM     #6 (permalink)
sick, thanks a bunch guys
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powering 24 pin motherboard with 20 pin power supply Samshen Motherboards 4 May 27th, 2006 10:13 AM
two 3-pin case fans on 1 3-pin mobo power slot? _Switch_ Motherboards 2 May 28th, 2005 03:20 PM
which cpu 754 pin or 939 pin asma123 General Tech Discussion 16 May 15th, 2005 11:39 PM
232 pin & 184 pin pc1066 RDram? massacres General Tech Discussion 3 May 15th, 2003 11:30 PM
72 pin & 168 pin memory, which to upgrade? desmocat Motherboards 20 October 18th, 2002 12:29 PM
Is It Just Me? (2992)
Intel Pentium 4 531 (7)
Please don't divorce us (40)
nVidia GTX 295 now available (19)
building a gaming computer, input p.. (14)
*TechIMO's Top 30 PCs* (44)
New psu question (1)
Finishing off my first built co.. (4)
AMD Phenom II X4 940 Black Edit.. (11)
Want to Buy a Home, But Can't Q.. (0)
New Build ( Finally ) (10)
Automatic updates turns off aut.. (0)
I think my PSU is dieing (4)
Core 2 Quad Q9550 system (3)
