Core 2 Duo E6300: 32-bit or 64-bit?
Currently Active Users: 2317
Discussions: 200,942, Posts: 2,379,297, Members: 246,305
Old July 31st, 2009, 06:17 PM   Digg it!   #1 (permalink)
Is the Core 2 Duo E6300 a 32-bit or 64-bit processor? I would like to upgrade to Windows 7 and get more RAM soon, but I can't seem to find this information out.
Or is this dependent upon the motherboard?
darrenlc is offline   Reply With Quote
Old July 31st, 2009, 06:31 PM     #2 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
As with almost every new chip its a 64bit cpu Intel® Core™2 Duo Processor - Specifications
Linus Torvalds
RicheemxX is online now   Reply With Quote
Core 2 Duo E6300 1.86Ghz or Pentium D Dual Core 3.4Ghz? UniquelyAm Processors, Memory, and Overclocking 4 September 20th, 2007 10:45 AM
Core 2 Duo E6300 temp rylenolflu Technical Support 28 July 25th, 2007 12:10 PM
AMD Athlon 64 X2 6000 or Core 2 Duo E6300 Nour Ershaid Processors, Memory, and Overclocking 3 July 22nd, 2007 11:53 PM
New Comp AM2 4600+ X2 vs. E6300 Core 2 Duo ? mypartsguy General Tech Discussion 12 January 29th, 2007 03:59 AM
Intel Core 2 Duo E6300 versus E6400, help! ilovethissite General Tech Discussion 28 October 18th, 2006 08:29 AM
The disrespect of Obama by Russian .. (6)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
