CPU pin repair  | | |
August 15th, 2009, 03:23 PM
Hey there i saw that there were other threads like this though they were rather old , I have a broken pin on a cpu , could i break a vss pin (black) and put it in the socket ? or for the ethernet cable trick do i take a single copper wire strand or do I take a portion of the cable with the sleeve. Thanks
August 15th, 2009, 03:32 PM
| | Super Duper Member
its broken completely off and not just bent right. You cant fix that on your own. there is no way you can properly attach the new pin properly to the CPU unless you have lots of experience with soldering. even if you do, you risk destroying your motherboard with it... and since you are asking here you probably dont have such skills. If you cant find someone who will do it for you (a jeweler might be able to) properly I suggest just getting a new CPU.
__________________ PII 720BE X3 @ 3.7Ghz | Gigabyte 790GX | HD4850 | 4gigs OCZ Reper | WDC 640gb Black Athlon II 250 X2 @ 3.80Ghz | Gigabyte 770 | HD4670 | 4 gigs OCZ Reper |
August 15th, 2009, 03:38 PM
August 15th, 2009, 04:42 PM
August 15th, 2009, 04:49 PM
| | SoMuchAnime-SoLittleTime
So how did he do it? You even watch the clip? |
August 15th, 2009, 05:10 PM
seems he put the broken pin in with a pair of needle nose directly into the socket and NOT on to the cpu , I wan to attempt this by breaking off one of the vss pins which are not needed and putting it in the hole where my needed broken pin needs to be , Just want a second opinion of someone who has done this or for more methods |
August 15th, 2009, 05:34 PM
Just get a piece of copper wire that is the right diameter and cut it to the right length. |
August 15th, 2009, 05:35 PM
a single strand or a portion of cable with the sleeve? |
August 15th, 2009, 06:34 PM
IMO you will need a single uninsulated strand that will bottom out in the mobo socket & be sticking up high enough to contact the CPU.
__________________ Rest peacefully little furry beast |
August 15th, 2009, 07:07 PM
| | Millwright
I've seen this repair before, JLK has the idea, if you use another pin it won't be long enough to bottom out and reach the CPU.
The piece of wire has to be bare, and just slightly longer than the space, so when you clamp in the CPU there is pressure on the replacement pin/wire.
Hard Sayin Not Knowin
