Thread: More memory at a slower speed?
May 7th, 2010, 11:16 AM #1Member
- May 2006
- Location
- Alabama
- 451
Ok, I have the option of running 1GB of 667mhz or 2GB of 333mhz memory in my dual boot Vista/Linux laptop. Which will perform the best?
Is more better or is faster better?
May 7th, 2010, 04:10 PM #2
It depends.
Are you maxing out 1Gig to the point, where the system is using the disk paging file a lot.
In that case it would be faster. Memory is always faster than a hard drive.
If you never go over 1 GIG the faster memory is faster, but probably not noticeable.
Although if you are short on RAM, going to 2 gigs should be noticeable.
You would have to see what your system is using for RAM, then probably try it.Hard Sayin Not Knowin
May 7th, 2010, 04:13 PM #3
Is this a dual channel board, and are both kinds of memory in pairs?
May 10th, 2010, 09:41 AM #4Member
- May 2006
- Location
- Alabama
- 451
It's DDR2 and can be run single. I will do some investigating this week to see if Vista is using all of the memory or not. I know that when I run Linux it's fine, when my wife runs Vista, it's slow. I thought having more than 1 gig would help Vista run better.
May 10th, 2010, 09:50 AM #5
Vista - hands down better with the 2 gigs even if you don't the machine on
May 10th, 2010, 10:10 AM #6
Even though I have never had Vista, I should have known it would use 2 gigs.
(Not to be confused with DDR2)
Most boards are what is called "dual channel", this means the memory installed in pairs will work in parallel, theoretically doubling the memory bandwidth. Running single sticks in this type of board, defeats the advantage of the design.
The newest boards have triple channel.Hard Sayin Not Knowin
May 10th, 2010, 12:35 PM #7Member
- May 2006
- Location
- Alabama
- 451
hmmmmm .. How can you find out whether a board is dual channel?
May 10th, 2010, 12:38 PM #8Member
- May 2006
- Location
- Alabama
- 451
Oops... never mind. It's says plainly on the spec sheet that it has dual channel support. So if I run a pair of memory sticks, they will run better, faster, stronger than they were before? (sorry, I love the Six Million Dollar man and allusions to the same).
May 10th, 2010, 01:01 PM #9
Yep, If you can run dual sticks, you should.
The real difference is smaller most of the time, that's why I said theoretically doubles your bandwidth, but it is faster.Last edited by stroyal; May 10th, 2010 at 01:07 PM.
May 12th, 2010, 09:25 AM #10Member
- May 2006
- Location
- Alabama
- 451
Ok.. here's the end of the story... A friend had a laptop that he crushed (don't even ask). It was running the same brand and speed memory from the factory that mine was (Hynix PC2 667mhz) He had 2 2GB sticks though to my 1 GB. I did some barter with him and I cut his yard and edged and trimmed the bushes in trade for the memory. It works fine and my machine at least seems faster to me.
I'm going to post another question about my processor. Thanks for all the advice.
May 12th, 2010, 09:39 AM #11
Glad to here it.
If you have Vista 32bit don't get worried, when you see it is not addressing all 4 gigs,
That's normal, 32 bit can only address 4 gig total, so you will only see about 3.5gig, depending on the amount of memory on your video card.Hard Sayin Not Knowin
May 12th, 2010, 09:47 AM #12Member
- May 2006
- Location
- Alabama
- 451
Yes, it shows 3.15gb or something like that... 256MB is used for video
May 12th, 2010, 09:56 AM #13
Perfectly normal, I mention video because it is the biggest other memory.
Windows has to address all the memory on the mother board to operate.
This includes video memory, BIOS ROM, I think there is a video BOIS also.
Any kind of memory has to be addressed, I think even, swap files on the hard disk.
For more system RAM, you need to go to a 64 bit operating system.Hard Sayin Not Knowin
Need help chosing memory speed vs FSB, CPU speed, etc.
By Zoltar in forum Processors, Memory, and OverclockingReplies: 0Last Post: September 21st, 2008, 07:44 PM -
Drastically Slower CPU Speed
By statdat in forum Technical SupportReplies: 1Last Post: January 20th, 2008, 04:02 AM -
CPU speed or Memory speed ?
By JRB3 in forum Processors, Memory, and OverclockingReplies: 4Last Post: April 20th, 2007, 02:45 PM -
Memory speed and FSB speed - best match.
By RAR in forum MotherboardsReplies: 4Last Post: October 7th, 2004, 05:25 PM -
Does memory speed affect clock speed?
By TC in forum General Tech DiscussionReplies: 2Last Post: February 5th, 2002, 11:32 AM
It's probably highly rated because of the level of violence. The story is decent.
Thread About Anime
