July 29th, 2010, 06:16 AM #1Junior Member
- Jul 2010
- 11
Intel Core i7 920 heat issue help please :D
Hello everyone out there, I am having a serious problem atleast from what I think.
I have bought a lot of stuff to my computer to change it out from the old one, kinda rebuilt it more or less eventho I just wanted a graphic card that was a little rush in... turned out to require me to get new motherboard, bigger computer case and this brilliant new CPU cause I choose a motherboard with that new kind of CPU types
I know I was very stupid and newcoming to change to a new graphic card and not knowing this but well. . . not what you wanna hear about now.
To the problem; Intel Core i7 920 HEAT issue
I am running the following programs to check my heat on my CPU;
OCCT
Speedfan 4.40
This is two great working programs from what I can understand.
The temperatures in the beginning when I got it was very high, I repasted it put it back together and it worked fine for around 2 months or so then the heat issues started but only on the cores which I find very wierd.
CPU was showing 40-50C which is quite high for you guys probably.
However the cores was showing up to 100C on most of the cores I can track 8 cores on this CPU.
I took it out cleaned it up and put it back together and put fresh new paste on it and now its running with 38C on CPU and the cores;
Core 0: 49C
Core 1: 46C
Core 2: 46C
Core 3: 48C
Core 4: 49C
Core 5: 46C
Core 6: 45C
Core 7: 49C
These are already some high heats if you ask me when I just started the computer a moment ago. they are jumping up to 10C over these temperatures I mentioned and back down again.
I am wondering how this can be?
Hardware;
Fan: Standard (I know I shouldnt expect much, but still this is A LOT of heat)
Paste: Arctic Silver Premium High-Density Thermal Compound
If anyone could give me some tips or solutions please post them cause I really need my computer its my living bread, also I would like to keep this topic clear and no immature replys if possible. :•)
Thanks in advance.
July 29th, 2010, 06:18 AM #2Junior Member
- Jul 2010
- 11
Oh yeah I also got another problem if any of you guys are very wise on SpeedFan and/or OCCT I would like to know why none of them can record the temperatures on my graphic card
they are both showing the first two GPU slots and doesnt show the third GPU slot that the graphic card is actually in.
heats just increased massively >.>
CPU: 61C
Core 0: 66C
Core 1: 65C
Core 2:61C
Core 3:67C
Core 4:67C
Core 5:66C
Core 6:62C
Core 7:69/70C
Running MSN, Skype, WMP and the game World of Warcraft
and checking with Speedfan 4.40 atm.
July 29th, 2010, 07:11 AM #3
Welcome TechIMO!
Assuming you are right about the temps being too high, I haven't looked it up, did you put too much thermal paste on?
It is not supposed to be a solid barrier, it is only for the places that don't touch metal to metal.Hard Sayin Not Knowin
July 29th, 2010, 07:19 AM #4
Google "Intel Core i7 920 temps"
Looks to me 60c loaded is pretty normal.Hard Sayin Not Knowin
July 29th, 2010, 07:20 AM #5Junior Member
- Jul 2010
- 11
100C cores are not normal on load
if it gets to 110C computer overheats.
and I havnt given it too much paste nope
July 29th, 2010, 07:32 AM #6
July 29th, 2010, 07:33 AM #7Junior Member
- Jul 2010
- 11
July 29th, 2010, 07:36 AM #8
July 29th, 2010, 07:43 AM #9
I,m wondering what it is really tracking?
that CPU only has 4 physical cores, and 8 thread.
What is the room temperature, and the case temperature.Hard Sayin Not Knowin
July 29th, 2010, 07:46 AM #10Junior Member
- Jul 2010
- 11
I am not sure how hot is is inside the case but its normally around 25-35C if I should go for what I think when I open the case to feel the air.
However the room temperature is normally very low around 15-25C
And I am not running on Full load on the cpu I am only on high performance, theres a program followed with the cpu which I can set to 3 states 2 of them being energy savings and then high performance and turbo, I dont dare to set it on turbo however I dont need it either.
July 29th, 2010, 07:58 AM #11
I don't understand why it worked for a while, what changed?
Your case temp will be with your other temps, it will be something like motherboard, or chip temp
If it is really 25c to 35c, it is too high, with proper case cooling, it should be the same or very close to room temp.
You can do a quick test with a window fan, blowing into the open case.Hard Sayin Not Knowin
July 29th, 2010, 08:15 AM #12Junior Member
- Jul 2010
- 11
windowfan? u mean I should try open the case and let it get cooled that way?
July 29th, 2010, 10:58 AM #13
Yes, just as a test.
July 29th, 2010, 12:52 PM #14Junior Member
- Jul 2010
- 11
July 29th, 2010, 01:02 PM #15i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
July 29th, 2010, 01:04 PM #16Junior Member
- Jul 2010
- 11
I know but these are After the repaste
but thanks and yeah I guess its normal for now but I think its gonna go up again, got a feeling about it. and I would like to know what solutions I should be having in my hand whenever it happens again cause I cant keep repasting it adventually I would get tired of it or do a mistake and maybe get paste on the CPU who knows. . .
all those random mistakes people can do.
July 29th, 2010, 01:09 PM #17i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
July 29th, 2010, 01:18 PM #18
what are you putting paste on, if your worried about getting paste on the CPU?
all you do is apply a thin layer to the heat cap ON the CPU, then apply the heatsink and secure it properly.
as to it happening again, if it is applied properly, and heatsink is secured properly, fans are working and airflow to cooler is set right, as well as ambient heat is vented out of case properly, then it shouldn't be happening again.
somewhere between 100 and 115C is the official MAX temps the 920 can handle, though its recommended not to go above 85C, otherwise the CPU and system is designed to shut down after that, though most motherboards, with their Overclocking options and features, tend to disable that feature.
right now for sh*ts and giggles, I installed speed fan, though I never use it because in past it never reported proper temps anyways, but running Folding@Home using the SMP client (full load on CPU, all 4 cores, 8 threads), plus Firefox and usual background stuff like Anti virus, and my temps are only hitting 69 to 70C max.
though I'm running an After market CPU Cooler, and have plenty of airflow in and out of my case, and using a top quality Thermal paste, but still, I have seen this rig hit 85C and slightly higher before on full load, running the CPU SMP client for F@H, as well as 2 GPU clients along side it (ambient heat in the case, builds up, as well as does the metal frame of the case from the GPU's)
Also, WoW is a very CPU intensive game, so if your running that, that will bring your CPU load up quite a ways as well.
July 29th, 2010, 01:21 PM #19Junior Member
- Jul 2010
- 11
I am just useing a tiny bit of thermal paste but when u have to clean it all the time meh
July 29th, 2010, 01:29 PM #20
you using the stock cooler?
what case do you have?i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
i7 920 Core temps & loads
By sword_fish in forum Processors, Memory, and OverclockingReplies: 17Last Post: May 27th, 2010, 10:29 PM -
By Cajunspirit in forum Processors, Memory, and OverclockingReplies: 28Last Post: May 22nd, 2010, 10:38 PM -
core i7 920 overclock temps?
By killer454 in forum Processors, Memory, and OverclockingReplies: 3Last Post: March 27th, 2009, 09:16 PM -
Intel Core 2 E6850 vs Intel Core 2 Quad Q6600
By Evenios in forum Processors, Memory, and OverclockingReplies: 2Last Post: August 23rd, 2007, 04:54 AM -
Intel 920 or X2 3800+?
By rabidaardvark in forum Processors, Memory, and OverclockingReplies: 14Last Post: March 14th, 2006, 03:26 PM
Inclement weather is preventing me from riding my bike, so it might as well be snowing.
