Results 1 to 6 of 6
    Ultimate Member joker_927's Avatar
    May 2002
    Oregon, USA
    2,436
    2 of 4 cores running slower?
    I am currently overclocking a QX9770 and I have it almost prime stable @ 4ghz. I am using RealTemp to monitor temps and I noticed that the temp of the 2nd 2 cores is ~5C less than the first 2. I didn't think much of it until I opened Everest for the first time and saw that it lists this:
    CPU #0 X9770 @ 3.20Ghz, 4003 MHz
    CPU #1 X9770 @ 3.20Ghz, 4003 MHz
    CPU #2 X9770 @ 3.20Ghz, 3768 MHz
    CPU #3 X9770 @ 3.20Ghz, 3768 MHz
    My FSB is set to 470 and the difference is 235 which would mean that two of my cores are running at a 0.5x multiplier lower than the other two.
    Anyone know why this is happening? Or is everest is even accurate?
    Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Corsair 650w
    Minnesota
    17,431
    any power management or CPU Throttling functions enabled?
    Could be the 3rd and 4th cores aren't running at full load, and clocked down?
    not sure really, only things I can think of off hand, been a while since I've used or had a S775 system and Core 2 Quad.
    Feb 2007
    Springfield
    13,484
    5
    The temp difference is pretty common. Most multi core chips will run at different temps, even if they are all under 100% load.
    Now the speed difference is odd. I've honestly never had that happen before. Maybe a power saving feature like shy said. Short of that, I'm not sure what it could be.
    What motherboard are you running on?
    FAQ's ~ Team Stats
    My PC
    May 2002
    Oregon, USA
    2,436
    I'm running on a Biostar TP45E Combo (it was the only 775 board frys had) and I'm faily confident this is a bug with the motherboard.
    If I disable overclocking in the bios the multipliers for all cores is 8x. As soon as I enable overclocking in the bios the multiplier on those 2 cores drops to the lowest, 6x.
    This sucks, I bought this board 16 days ago and fry's return policy is 15 days. It would make sense to contact Biostar...
    I Haz Catputer JLK03F150's Avatar
    GA
    5,437
    It looks like Biostar has a BIOS update to correct some sort of overclocking issue.
    BIOSTAR :: TP45E Combo :: BIOS
    May 2002
    Oregon, USA
    2,436
    Thank you for the link. First thing I did was update the bios when I got the board. Biostar has a very easy windows programs that updates via the web.
    I have sent a bug report to BioStar so I'll be hoping for the best...
  1. Processor Vs. cores
    By SammyThePenguin in forum General Tech Discussion
    Last Post: March 4th, 2010, 07:27 AM
  2. 6 cores already, but no i9
    By cksboy15 in forum Tech News Discussion
    Last Post: January 31st, 2010, 02:19 AM
  3. My 6600GT is running slower than usual!
    By gunstar in forum Graphics Cards and Displays
    Last Post: April 29th, 2005, 04:25 PM
  4. Cores
    By TheFuch in forum Processors, Memory, and Overclocking
    Last Post: February 21st, 2005, 02:27 AM
  5. ECC2 running two cores
    By swamp-fox in forum Distributed Computing
    Last Post: February 7th, 2003, 09:11 PM
