Results 1 to 2 of 2
    Nov 2010
    Vancouver BC
    Post HELP: Memory Parity Error
    Turn on computer or re-boot and I get this message:
    Hardware Malfunction
    NMI: Parity Check/
    Memory Parity Error
    ***The system has halted***
    Husband installed extra memory and now I get this message. I have to un-plug my DLink wait 30 seconds, plug it back in and windows loads.
    We removed the extra memory and it still did the same thing. I have a ThinkCenter and am getting no answers from Lenova.
    Please someone HELP! Thanks in advance.
    Ultimate Member quickoldcar's Avatar
    Oct 2004
    NE Pennsylvania
    1,005
    Sitting here thinking how the d-link plugged in is connected to this issue.
    Well try no d-link plugged in, or if you removed the new memory already and does the same, try removing the battery on the motherboard for a few minutes, then place it back and hope everything works.
    Then if it's actually because your ethernet port is bad on the motherboard can deal with that by adding an ethernet pci card or going wireless.
    I don't really have much more as for suggestions on this.
    DynaIndex.com - Dynamic search index of websites, links, feeds, title, description, keywords and thumbnail snapshot.
  1. NMI:Parity Check/Memory Parity Error
    By camaro in forum Technical Support
    Last Post: January 17th, 2013, 09:41 AM
  2. nmi parity check memory error hp
    By joker12578 in forum Technical Support
    Last Post: August 31st, 2010, 09:33 PM
  3. NMI :parity check memory parity error
    By malatri in forum Technical Support
    Last Post: November 26th, 2008, 01:40 PM
  4. BIOS memory error after memory install
    By Paul1985 in forum Processors, Memory, and Overclocking
    Last Post: February 28th, 2008, 11:00 AM
  5. 164 memory error with a dhcp boot error
    By sweetpea60a in forum Technical Support
    Last Post: February 3rd, 2008, 07:04 PM
