Results 1 to 3 of 3
    Nov 2010
    Changed Cpu on my laptop but monitor wont turn on. Please help!!
    I have an Acer Aspire 5100 and it used to have a single not dual amd turion 64 2.0 ghz cpu socket s1. i bought a amd turion ii ultra 2.5 ghz socket s1. I installed the cpu and turned everything on. The power light and fan look and sound like they are running but the monitor wont turn on. i switched to the old cpu and the monitor turns back on but not with the new cpu. I dont kow whats wrong with it and why the monitor wont turn back on with the new cpu. Please help
    NOVA
    33,807
    46
    Are you sure the laptop supports that processor?
    Jan 2003
    Outside the box
    8,489
    4
    Just a guess from looking at the specs I'd say your laptop does not support the much newer Turion Ultra II. Just because a chip is the same socket doesn't mean the board can support it because many OEMs don't update bios information on older boards to support the new chips.
    AMD Turion™ 64 X2 dual-core TL-50/TL-52/TL-56/TL-
    60/TL-62 processor or higher with 1 MB L2 cache,
    supporting AMD PowerNow!™ Technology and AMD
    HyperTransport™ Technology
    • Mobile AMD Sempron™ 3200+/3400+/3500+ or
    higher with 512 KB L2 cache, supporting AMD
    Specs from Acer
  1. monitor wont turn on :(
    By western123 in forum Technical Support
    Last Post: August 12th, 2009, 09:10 AM
  2. monitor wont turn on
    By wigbreak in forum General Tech Discussion
    Last Post: May 22nd, 2009, 03:21 AM
  3. Monitor Wont Turn on.
    By KraidSaves in forum Technical Support
    Last Post: April 29th, 2005, 07:32 PM
  4. Monitor wont turn on, Computer wont boot. HELP plz.
    By Drakarn in forum General Tech Discussion
    Last Post: September 30th, 2004, 02:26 AM
  5. monitor wont turn on help help
    By jarno77 in forum Motherboards
    Last Post: January 17th, 2004, 06:39 PM
