Results 1 to 6 of 6
    Dec 2010
    4
    clariyfing cpu speed
    hi...using a Dell Inspiron 8600 with Intel Pentium M processor rated at 1.8Ghz...1 gig of DDR1 Ram (333 Mhz)...Windows XP Pro SP3...
    Although the processor is rated at 1,8Ghz system info says processor speed is only 598Mhz.
    Is this the top speed of this processor?
    Power settings are currently set to Always On and the laptop is plugged into AC.
    thanks
    pc
    Dec 2010
    UK
    24
    It could be possible that your CPU is overheating, and that is causing it to throttle. Does it run at this speed after a while or does it run like this from the start
    Nov 2006
    Portsmouth, UK
    4,159
    Run a program and check the speed while it loads up... Chances are power saving/speedstep is enabled which will lower the CPU multiplyer and v-core making it run at a slower speed. It should go back to normal whenever you put load on it.
    Dec 2010
    4
    Thanks for the replies...
    The speed remains the same from start up to shut down and doesn't vary when applications are launched...I've booted six separate applications including Outlook, Word, Excel, Firefox, and a few more....
    I was worried about overheating as the btm of the laptop became quite hot. I purchased a notebook cooling pad/fan that the computer sits on.
    Could the overheating have damaged the processor permanently?
    Dec 2010
    4
    I installed speedswitch earlier this afternoon....even when CPU load maxes out to 100% the cpu speed remains stuck at 598Mhz rather than bumping up....
    Dec 2010
    4
    Ok...figured it out....in BIOS the speedstep function had been disabled which limited the CPU to its slowest speed. I recently had my laptop in for service and recall the tech mentioning this...which is why I went back to check. I recall telling him that the cpu was maxing out on start up and remaining maxed out for 10-20 min...he double checked the speedstep and must have made the change there...not 100% why...
    Anyway, I turned the speedstep function back on and max speed is back to 1.8Ghz...currently throttling correcting as demands change.
    thanks to all
  1. Processor bus speed and changing CPU speed.
    By Cal20 in forum Processors, Memory, and Overclocking
    Last Post: October 24th, 2008, 08:21 AM
  2. Need help chosing memory speed vs FSB, CPU speed, etc.
    By Zoltar in forum Processors, Memory, and Overclocking
    Last Post: September 21st, 2008, 07:44 PM
  3. CPU speed or Memory speed ?
    By JRB3 in forum Processors, Memory, and Overclocking
    Last Post: April 20th, 2007, 02:45 PM
  4. CPU speed vs. FSB speed
    By Krum in forum Motherboards
    Last Post: August 11th, 2003, 05:16 PM
  5. Upgrade CPU speed, and Network Speed
    By shadows in forum Mobile Computing
    Last Post: June 13th, 2002, 11:49 AM
