Results 1 to 6 of 6
    I got this #43 fan's Avatar
    Mar 2005
    Midwest
    5,560
    Fan speed control
    Hello, all:
    I was wondering if anyone knows of a good utility that controls fan speed/rpms.
    I have tried speedfan, but it doesn't work on the Optiplex 380 that I am working on.
    Thanks for the help
    Dallas, TX
    12,375
    I've never installed speedfan or anything similar... If the fans spin when I plug em in and the pc doesn't overheat - I'm good to go.
    But, the mobo/BIOS has to support the ability of reporting the info to the operating system/speedfan... Considering how limited Dell BIOS's are - you might be out of luck.
    Mar 2005
    Midwest
    5,560
    The reason that I want to up the fan speed is to see whether one of the bearings is bad.
    The RPM's of the videocard (which is the most likely suspect so far) are so low that I can't really tell if the bearing is bad or not.
    Unfortunately, Catalyst Control Center is not working properly, but I am working to get that fixed asap.
    But thanks Steve for responding.
    Unavoidable Member nickslick74's Avatar
    Jul 2006
    Land of 11,842 lakes
    11,571
    What brand video card? I ask because many manufacturers provide an overclocking utility that can also allow you to mess around with fan speeds. I do it all the time with my MSI card.
    The timing of death, like the ending of a story, gives a changed meaning to what preceded it. -Mary Catherine Bateson-
    Dallas, TX
    12,375
    I'm guessing you've cleaned the heck out of all fans... What makes you think you have an issue with ball bearings?
    Mar 2005
    Midwest
    5,560
    Yes, the fans were clean (the computer was only a few months old).
    But it turns out it seems like it was a vibration issue.
    But, I am keeping an eye on it.
    Thanks again.
  1. Fan Control
    By Micro Bean in forum General Tech Discussion
    Last Post: April 3rd, 2007, 12:53 AM
  2. Control ATI X1900XT fan speed?
    By nubcake in forum General Tech Discussion
    Last Post: March 20th, 2006, 09:00 PM
  3. Fan Control
    By the mitch in forum Applications and Operating Systems
    Last Post: July 29th, 2005, 09:03 PM
  4. Case Fan Speed Control
    By dr_roberts49 in forum General Tech Discussion
    Last Post: January 15th, 2004, 10:25 PM
  5. Software fan speed control!
    By Solid Snake in forum PC Modification
    Last Post: August 2nd, 2002, 11:23 PM
