Thread: Need help upgrading memory!
February 23rd, 2011, 03:09 PM #1Junior Member
- Feb 2011
- 28
I have a Fry's computer
Model FM7540
Fry's PC FM7540
on the link it says expandable to 3 gigs but im only getting 1.99 how do i get it to 3 gigs and what ram sticks should i buy!!(newewgg links would be cool!!) thanks
February 23rd, 2011, 03:27 PM #2
If you're running XP - another gig probably won't make much difference usless you're doing some real serious work on the machine...
Memory: 512MB DDR SDRAM (expandable to 3GB)
DIMM Slots: 4 (2 open)
Odds are you are currently using 4 x 512 meg sticks... you'd have to take two out and replace them with two 1 gig sticks.
This free app will tell you much more about your current ram sticks so that you can try to get the exact same type:
Download siw.exe Free trialImagine a world where dogs took bad owners to the pound...
February 23rd, 2011, 03:30 PM #3Junior Member
- Feb 2011
- 28
Could my computer even run windows 7??
and would it make it faster??
February 23rd, 2011, 03:49 PM #4
Windows 7 generally needs more power then XP.
Windows 7 Upgrade Advisor
Free Download PC Upgrade Advisor Windows 7 Hardware Programs IssuesImagine a world where dogs took bad owners to the pound...
February 23rd, 2011, 04:44 PM #5Junior Member
- Feb 2011
- 25
Win7 isn't that much of a pig. Though it is more than XP.
I have it running (x86 ultimate) on my netbook with an Intel Atom N260 and 2GB RAM. It idles at 1-7% CPU and about 550MB RAM used with full Aero glass desktop. I have done a few minor tweaks (like ditching the sidebar and other useless services).
February 23rd, 2011, 04:54 PM #6
As it relates to the OP's post however it would in no way be beneficial for him to upgrade as he's not going to see a 'speed boost' on an old p4 machine.
If you are seeing slow downs, or performance issues you might check for viruses, malware ect. Do a defrag, remove any un-needed startup entries (programs that run at start-up that you don't need) run a registry cleaner like CCleaner or maybe even do a fresh install.
February 23rd, 2011, 05:04 PM #7Junior Member
- Feb 2011
- 25
upgrading memory
By watco in forum Technical SupportReplies: 4Last Post: March 1st, 2009, 04:25 PM -
Upgrading Memory
By jeet in forum General Tech DiscussionReplies: 11Last Post: December 7th, 2004, 05:53 PM -
Upgrading Memory
By Ed-In-Tx in forum PC ModificationReplies: 4Last Post: August 12th, 2004, 01:37 AM -
Upgrading Memory
By Ben Humphreys in forum General Tech DiscussionReplies: 2Last Post: May 10th, 2004, 09:39 PM -
PC2300 memory? Upgrading memory.
By RAR in forum Technical SupportReplies: 1Last Post: April 9th, 2003, 01:30 PM
at least you have some space between them so the primary card has some air flow to it. 75-80C is about average for temps on those, my 560 Ti's do about the same in a lot of games, some games run...
Temps too high? ( GTX 580s )
