Results 1 to 5 of 5
Thread: Water cooling?
    Jun 2011
    13
    Water cooling?
    Dear everyone,
    I made a computer with the following specs:
    i7-2600K
    ASUS GTX 560ti CU II Top
    ADATA Gaming Series 1600mhz 4GB X 2 Kit
    Asrock Z68 Extreme 4
    Cooler Master 650 80+ Bronze
    Chassis is:
    Cooler Master Silencio 550
    I'm planning to overclock the i7 to around 4.5Ghz.
    I'm not sure if fans would be enough to cool my computer down. And even if they were, they would make too much noise (I chose the Silencio chassis because I don't want noise >.<).
    My friends tell me to consider water cooling, but I have no idea if it really works.
    Can anyone suggest good water cooling systems, or explain how a water cooling systems works? Furthermore, if you could, please compare fans to water cooling.
    THX!
    GA
    5,413
    I have been water cooled on my CPU for about six years. It will certainly get you a much better overclock than air coolers. There is a water block mounted on the CPU, water circulates by a pump to the radiator. The radiator has noisy fans mounted on it to remove the heat from the water.
    This kit is an updated version of the kit I bought years ago...
    Swiftech H20-220 Apex Ultima XT Liquid Cooling Kit
    Jun 2011
    13
    Quote Originally Posted by JLK03F150 View Post
    So do you recommend water cooling?
    GA
    5,413
    Absolutely. I don't think I'll ever go back to air on my main gamer's CPU.
    I killed an HD 4890 video card while simply mounting a water block - stock air cooler for my video, but water for my Q9650 CPU at 4.0+ GHz.
    Nov 2006
    Portsmouth, UK
    4,159
    If you can deal with the maintenance and the large upfront cost then yes its definitely worth it.... Though if you just want to occasionally blow away the dust and that's it..... Stick with air.
    Most 2600Ks can hit 4.5Ghz on air.
  1. CPU Cooling. heatsink/water cooling???
    By jamhough22 in forum Processors, Memory, and Overclocking
    Last Post: July 19th, 2008, 08:18 AM
  2. water cooling
    By survivalhero in forum General Tech Discussion
    Last Post: September 3rd, 2004, 06:08 AM
  3. Water Cooling
    By njolakoski in forum Processors, Memory, and Overclocking
    Last Post: April 29th, 2004, 10:07 PM
  4. water cooling
    By shady06 in forum PC Modification
    Last Post: May 17th, 2003, 02:26 PM
  5. PC Water cooling
    By Mercenary Dragon in forum PC Modification
    Last Post: June 19th, 2002, 09:59 PM
