September 13th, 2002, 02:21 PM
| Running without side panels
hello all,
I'm running my desktop without the side panels in a pathetic effort to lower my temps. Would this be advisable in the long run? Is it more effective (in terms of heat dissipation) to run without side panels or to install fans? |
September 13th, 2002, 02:25 PM
well, I ran my PC w/o a fan for a long time. The only bad thing is the amount of dust that gets in there, and also if you're not careful other objects can land inside your PC.
By getting fans you increase the noise level, but you also increase the airflow. |
September 13th, 2002, 02:29 PM
I have a small old CPU fan dangling inside and one side open. Works well for me and very little noise. | |
September 13th, 2002, 02:40 PM
shahani > dangling? please post a pic - sounds a touch precarious, if I might make so bold  |
September 13th, 2002, 02:46 PM
Ok, hanging by a wire. The old CPU fan circulates air inside the case. I have a 350W PS and 3 drives, an entry level (cheapo) 800MHZ duron, a cr writer, nothin' fancy. | |
September 13th, 2002, 02:50 PM
aww shahani - no pic  |
September 13th, 2002, 02:51 PM
ROFL! dangling on a wire? haha, that's good.
Actually, even with how odd it sounds, i am considering doing the same thing in my case to get a little added airflow.
I don't think I'm up to the task of cutting any holes in my case to add fans, so I might as well just rig one up with a wire to hang down over the cpu/mobo. |
September 13th, 2002, 02:54 PM
| | A hero in training
all my machines at home have no side panels. a quick clean some with some canned air when they need it is all that is required. it depends on how cool your house is or the area your computer sits. |
September 13th, 2002, 02:55 PM
| | Thaumaturge Member
| Re: Running without side panels Quote: Originally posted by mc2310 ...I'm running my desktop without the side panels... | What? computers have side panels?!  |
September 13th, 2002, 02:56 PM
mc:
Are we to assume that you have no front intake or rear exhaust fan mounts in that case??
- Bill |
