all intel cpu's are "locked" only engineering samples are unlocked . you may have seen reviews on websites with unlocked cpu's but you cannot buy them.
you may over clock the front side bus on your motherboard to overclock you p4 i have two a 1.8 running at 2.4 and a 2.2 running at 2.8 good luck
