Results 1 to 5 of 5
Thread: Fan question
    ILC
    ILC is offline
    Senior Member ILC's Avatar
    Eastern Shore
    701
    Fan question
    Alright, may sound silly but...which way should the CPU fan be blowing?
    Air into the heat sink, or pulling air through the heat sink and dispersing heat?
    Thanks.
    ILC
    Dec 2001
    NY
    4,519
    it should blow air onto the h/s.
    Member Bones1's Avatar
    Brooks, Alberta
    444
    I'd have to say through.
    All the ones I've seen force air into the heatsink (with the exception of some Dells and some HP's).
    Member littlebird's Avatar
    Oct 2002
    Caribean Skies (P.R., D.R, etc.)
    198
    It depends of your other fan setup inside the case. But usually, like PJ says, you want the fan to blow air onto the heatsink.
    Ultimate Member Jeordiewhite's Avatar
    Feb 2002
    midvale, utah
    2,315
    Yes you do that when you have cool air going towards your hs, I get a degree cooler when I blow it away from the processor, It usually depends on your setup.
    (´¸.·*´¯`*»- ->Jeordiewhite
