Join TechIMO for Free!
Thread Tools
Currently Active Users: 1717
Discussions: 188,474, Posts: 2,244,163, Members: 232,721
Old December 28th, 2002, 02:29 PM   Digg it!   #1 (permalink)
Banned
Send a message via AIM to iNeb
Help with AMD 2400+ -OEM (Help me buy)
I have no idea about computer hardware so help me learn.
AMD Athlon XP 2400+ -OEM
I plan on getting that processer for my new computer i plan to build, so...
1) Any better prices then that? I'll look at my local store when ads come out tomorrow.
2) What motherboard ATX (model and maker) should i get that works good with this? 1AGP, 5PCI (Don't really need onboard audio/video but ok if can be diabled), Onboard raid is no...
3) What is a good fan/heatsink for this? I have heard Volcanos are good, but what model? If not valcano, then what?
4) What powersupply won't waste my system? I'm thinking 400Mhz to be safe or so.
How did you choose these? I want to know what to look for so i can look for them on my own if needed
Edit just found this for 5$ cheaper, anyone know about this company?
http://www.googlegear.com/jsp/Produc...ductCode=80166
iNeb is offline   Reply With Quote
Old December 28th, 2002, 02:45 PM     #2 (permalink)
Banned
http://www.newegg.com/app/ViewProduc...ion=11-125-313
What about this case? It looks nice to me, has a window and it has nice spacer + 3 fans, front USB and firewire, would i need a firewire card for it?
It has 4 fans, but would it be quiet? I like to leave my computer on while i sleep...
-EDIT Also found this (Whats the difference?) It's cheaper and comes with power supply (all i could see was no firewire)
CHENMING Server Chasis (Workstation Tower) Model DX-01SLD 420W SILVER COLOR w/ large acrylic window **Now w/ Front USB ports** AMD Approved Power Supply Front Accessible: 4 x 5.25", 2 x 3.5", Internal: 4 x 3.5". Power Supply: Turbo Link (P4) 420 watts ATX 12V- w/ 2 Case Fans Model#: DX-01SLD SPX-02 420W
http://www.newegg.com/app/Showimage....125-146-09.JPG
Old December 28th, 2002, 03:01 PM     #3 (permalink)
Richard Cranium's Avatar
We all have opinions, I'll offer mine.
Drop back to the "Retail" XP2000+ for $91
http://www.newegg.com/app/ViewProduc...ion=19-103-327
This saves you about $90
Use the extra money for some extra ram
Crucial PC2700
http://www.crucial.com/store/listmod...ackage&cat=RAM
The Power Supply wattage needed is directly related to how much stuff you plan to run.
If you're like most, One Hard Drive & One CD-Burner and a couple of fans is the average.
A 250w "quality" power supply will furnish those needs.
Here's a 300 watt unit in a good case for $46
http://www.techimo.com/forum/t46117.html
Or a stamped steel case w/350w for $42 shipped
[I love this case]
http://www.compgeeks.com/details.asp?invtid=500SEL
The fan issue for the CPU is debatable, one unit that comes to mind is the Cooler Master HC001
$30
http://www.newegg.com/app/ViewProduc...ion=35-103-130
I suggest the lower components as the 'New' stuff is overpriced IMHO
Doc
{C
Richard Cranium is offline   Reply With Quote
Old December 28th, 2002, 03:08 PM     #4 (permalink)
Banned
Hmm, that might be a good idea to save me money..
What can 330 Mhz do for me besides save me 100 bucks
But i do like having 2.0Ghz
AMD ATHLON XP 2100+/266 FSB PROCESSOR CPU - OEM for 95$
Or for 7$ more retail..
Old December 28th, 2002, 03:13 PM     #5 (permalink)
Well, I notice no difference operating my Duron 1.0ghz builds compared to the 1700+ XP or the Celeron 1700mhz units.
Seriously, unless you're planning on doing Video Editing or some other very heavy load process, the super fast machines are of no benefit.
[IMHO]
Old December 28th, 2002, 03:19 PM     #6 (permalink)
Banned
Well too me it's just a thought of having 2.0Ghz i'll probley go for a lower ammount
http://www.computerbrain.com/cbisys/...le=cpus&id=114
AMD Athlon 2100+ for 85$
How easy would it be to overclock the 2100 or 2000?
I have never over clocked before so...
Old December 28th, 2002, 03:36 PM     #7 (permalink)
That one is OEM [30 day warranty] No Cooling Fan & Heat Sink
The ones I linked ya to are "Retail"
3-yr warranty and includes a Heat Sink & Fan
Forget overclocking for now, you may get items that allow it, but you need to crawl before worrying about running.
Most motherboards today have overclockng built into the BIOS, no more jumpers being set with tweezers and a magnifying glass while using a calculator to figure out the correct settings.
Old December 28th, 2002, 03:46 PM     #8 (permalink)
Banned
Well if i was to get the Athlon 2000+ (which i might go ahead an do)
What kind of mother board would i have to get that fits the specs i needed so i can upgrade my chip at a later time (like 2500+ or so)
So i'm looking for:
AMD MB (ATX)
Works with 2000+ (and will allow me to upgrade at a later time to something higher if needed)
DDR 2100 (or more) (2-3 slots) allows me to put 2 512 DDR sticks in (I will put 1 for now maybe 256 later on if needed, but to be safe)
Opinional onboard sound/video/lan (but can be turned off)
1AGP slot 5PCI
No Raid
Also why is DDR is pricey?! I might just get the 2100 kind
http://www.crucial.com/store/listMod...DIMM&submit=Go
What's the diff between all the 256MB ram
Old December 28th, 2002, 04:07 PM     #9 (permalink)
Asus A7V8X or Asus A7N8X. these 2 boards are great. packed with features and easy OC'ers and both boards accept DDR 2100 and DDR2700 and not to mention DDR3200.
The A7N8X says it accepts up to 2.8 ghz> Since AMD has not reached this plateu I would assume that you could use it for quite some time. Very upgradable.
Both of these boards come with or without raid.
The A7N8X Delux comes with vid and sound the non delux just has sound
The A7V8X has 2 versions one with raid one without neither have Video both have sound.
Hope this helps some
Wolf
Wolfman11511 is offline   Reply With Quote
Old December 28th, 2002, 04:32 PM     #10 (permalink)
Banned
Those are a little pricey...
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2993)
Intel Pentium 4 531 (7)
Please don't divorce us (40)
nVidia GTX 295 now available (19)
building a gaming computer, input p.. (14)
www.98CNSHOES.com sell D&G,.. (1)
1cdkey com\battlefield 2142 cd .. (0)
*********** day of defeat sourc.. (0)
1cdkey com \warcraft cd key,war.. (0)
www.***********//Diablo 2 Combi.. (0)
CPU Overheating ?? (18)
*TechIMO's Top 30 PCs* (44)
Core 2 Quad Q9550 system (3)
