February 20th, 2003, 12:45 PM
| Slot 1/socket 370 adapter card inside Pentium II case?
W/a Slot 1, Pentium II 350, is that actually a slot 1/socket 370 adapter card inside the case? If so, could I take it apart and use that card for my new socket 370 Celeron 1 MHz? |
February 20th, 2003, 12:54 PM
No, thats not a slotket adapter that your Pentium II 350 is on....its an entire unit with the CPU core permanently attached to the PCB.
You're going to have to get a slotket adapter if you want to use your Celeron in a slot 1 motherboard.
Through the NIC, on the cat5, off the gateway router, out the cable modem...….nothin' but net.
I'm not sure I follow your question.
Are you asking if your PII 350 is mounted to an adaptor, allowing it to be installed in a Slot I board? |
February 20th, 2003, 12:56 PM
Yeah, what Target said. AFAIK all PII's were slot I. |
February 20th, 2003, 01:27 PM
Thanks -- when looking "inside" the Pent II's case, it looks very similar to a Celeron-like processor stuck on a slot 1/socket 370 adapter. Ya, I got the adapter coming, just getting impatient.... |
February 20th, 2003, 01:31 PM
| | Let's go, Hokies!
BFlurie, I ordered one a couple weeks ago from buy.com and it came in two days. That was paying for the cheapest shipping they had. (Now I'm just waiting for the Celery 700 from Compgeeks.) |
February 20th, 2003, 05:25 PM
I just go the slocket adapter in the mail-o, so it's hip-hip-hip and awaaaay I go..... |
