Join TechIMO for Free!
Thread Tools
Currently Active Users: 1739
Discussions: 188,468, Posts: 2,244,156, Members: 232,719
Old February 23rd, 2003, 04:51 AM   Digg it!   #1 (permalink)
Question
replace fan or not?
as i said earlier i just purchased some new fans..one being the tornado 80mm fan. I am currenlty running the volcano 7 modded so it runs full blast at 5000rpm always. I was wondering, since sound is not a issue, if i should replace the thermaltake fan with the tordano? Since it runs the same db but 84cfm?
well going to bed..let me know what yall think.
btw when i get everything in and installed ill send some pics of my first modded case.
les
asus a7v333
xp 2000 w/ volcano 7/ac3
ti4200 64meg video card
litey 48x12x48 cdrw
6x dvd
256meg ddr pc2700
lreid is offline   Reply With Quote
Old February 23rd, 2003, 05:00 AM     #2 (permalink)
Are you going to overclock your processor? If so then switch them. Hopefully noise really isn't a concern.
rourkchris is offline   Reply With Quote
Old February 23rd, 2003, 05:53 AM     #3 (permalink)
cunokyle's Avatar
Send a message via AIM to cunokyle
what temps are you running now? If nothing unusual, I am unsure as to why you would. If you are going to overclock and are concerned about temps, definitely swap it in there.
BTW-how did you mod the volcano 7 to run at full speed all the time? I want to do it to mine but wanted to know what to do first.
cunokyle is offline   Reply With Quote
Old February 23rd, 2003, 06:15 AM     #4 (permalink)
Bullion's Avatar
Send a message via ICQ to Bullion
you need to bypass the temp sensor. I modded mine to use a switch so i could choose between full blast and temp controlled. Search in google, it should come up with something useful. It is a good heatsink i liked it better then the 7+ i got to replace it but watercooling is the best so quiet!!
Bullion is offline   Reply With Quote
Old February 23rd, 2003, 12:26 PM     #5 (permalink)
well basically i took the temp module out of the equation..kept it just in case i wanted to go back..just cut the thermal resistor out and splice wires back...full speed ahead baby!..my temps are running ( full blast at about 107 idle 113 full load) modding the volcano dropped it about 4-5 degrees f by itself. I also took a old 80mm fan that the bearings were gone and clipped the fan from the middle to leave just a 25mm spacer. I put that between the modded fan and heatsink..looks huge but i think that helps a little with getting more air to center of heatsink. I also tried to (when thermister was connected to fan) to stick down inside of heatsink. It helped a little brought up rpms from 2000 to 3500.
thanks, les
Old February 23rd, 2003, 12:51 PM     #6 (permalink)
I have a tornado and it really is loud! Hope you won't be around that screamer to long. I have mine on a rheostat so I can control it. If the ambient starts getting a little warm, I crank it up a notch, but boy does it scream but very effective.
hukilau is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2992)
Intel Pentium 4 531 (7)
Please don't divorce us (40)
nVidia GTX 295 now available (19)
building a gaming computer, input p.. (14)
CPU Overheating ?? (18)
*TechIMO's Top 30 PCs* (44)
New psu question (1)
Finishing off my first built co.. (4)
AMD Phenom II X4 940 Black Edit.. (11)
New Build ( Finally ) (10)
Automatic updates turns off aut.. (0)
Core 2 Quad Q9550 system (3)
