CPU Upgrade? Will it work?  | | |
February 24th, 2003, 06:33 PM
#11 (permalink)
I get a 403 error or in other words: you are not authorized to view this page. |
February 24th, 2003, 06:34 PM
#12 (permalink)
FC-PGA 2 is the Tulatin core. It had a different I/O Voltage to it, so it wouldn't work with an older motherboard.
I think the only chipset that Intel made that supported the Tulatin was the 815T or something like that. |
February 24th, 2003, 06:47 PM
#13 (permalink)
So that means that it won't work or it will only work with an adapter? If it won't work period, what is the fastest one that I can get for it?
February 24th, 2003, 06:49 PM
#14 (permalink)
With the adapter, I was able to use a P3 tualitin on a board that had a celery 700. It should have no problem working with the adapter.
-Kc2iLq |
February 24th, 2003, 06:57 PM
#15 (permalink)
February 24th, 2003, 07:04 PM
#16 (permalink)
Do a google search on FCPGA to FC-PGA 2 adapters. Click on the 3rd one down or so from Pricewatch. Scroll down to the 9th listing and click on the link Buy Online from the package2you listing. Should take you right to it. Should see it as the second item listed. |
February 24th, 2003, 07:07 PM
#17 (permalink)
Ok, I got it. thanks. I will let you all know if it works. |
February 24th, 2003, 08:04 PM
#18 (permalink)
February 24th, 2003, 08:06 PM
#19 (permalink)
That's a P4 fan and won't clip onto the socket.
-Kc2iLq |
February 24th, 2003, 08:08 PM
#20 (permalink)
Oh, ok. I didn't know if that would work for it or not. I just paid attention to the price and that is the only fan that that company has for sale. Seeing that is where i am going to buy the converter. I have to buy a converter for the other computer, too. |
