April 13th, 2003, 01:23 AM
| | Banned
I dunno if this is an issue, although it kinda concerns me.
I bought a Volcano 7 by thermal take and i can never get it to go over 3000 rpms. I just idles there however the cpu never over heats. However, when i touch the temp sensor on the fan, it speeds up to 5000 rpm. I would like it to stay there to keep the cpu cool.
Is this normal for a Volcano 7? Is it possible to change out the fan if I needed to? |
April 13th, 2003, 01:39 AM
It doesn't sound like a fan issue to me... did yours come with a limiter?
Mine had one... I set it to high... I never tried medium or low...
And are you hooking it up to the board or through a normal plug from the psu?
If I recall correctly when I bought mine... they said you had to hook it up from the psu's power. Not from the mother board or you'll burn up your processor..
(´¸.·*´¯`*»- ->Jeordiewhite
April 13th, 2003, 01:41 AM
| | Kawaru wa yo!
With a little cajoleing, you can get the thermistor inside the heat sink fins. Keeps mine up around 4500 all the time. Otherwise I think you could cut the thermistor out and splice the wires together. No resistor = no resistance. It's either that, or then it would never run fast... Heh. |
April 13th, 2003, 01:47 AM
| | Banned
putting the sensor in the fins? sounds easy.. will try that and let you know.. splicing wires are my last resort. |
April 13th, 2003, 01:55 AM
I cut out my sensor and spliced together the wires to run at full speed all the time, I run at a little over 5300rpm. |
April 13th, 2003, 02:01 AM
| | Banned
can you show me a picture? I would like to see this.. i tried putting it between the fins. I got up to 3600 rpms (average) |
April 13th, 2003, 02:07 AM
Sensor? what sensor?, mine didn't come with one. |
April 13th, 2003, 02:09 AM
| | Banned
the thermal take volcano 7 comes with a little green or brown sensor that lets it take the temp and adjust the fan speed. I am trying to get mine to go up some. |
April 13th, 2003, 02:10 AM
The volcano 7 or 7+, becuase I have the 7+, and it didn't come with any sensor. |
April 13th, 2003, 02:13 AM
| | Banned
the 7, not the 7+. I screwed up on title. |
