Thread: fans window mount
May 6th, 2003, 05:07 PM #1
fans window mount
I just got 2 thermaltake smartfan II's and will replace my 80mm antec fans (one intake front, one exhaust rear) with them. I want to cut my acrylic side window and mount the antec fans across from the heatsink. Is exhaust the best way to run them? I will use a dremel tool to make the cuts. any tips on how to make the cuts will be appreciated.
Thanks,
WaynezoWaynezo-Windows 7 Pro/Core i7 920
Asus P6T Deluxe V2/2 ATI Radeon HD 4770 Video Cards
6GB OCZ Gold DDR3 1600/Intel X25-M 80GB SSD HD
May 10th, 2003, 02:10 AM #2AlexanderAkulickGuest
May 10th, 2003, 03:01 AM #3
Intake is the best to run the window fan...directly across from the CPU...and the best way to cut the window is...tape it up with masking tape...mark your hole...take a hole saw and a drill...set the drill to about 25% of the power...slowly, without putting a lot of pressure on the drill, drill the hole...then take a massonary drill bit to drill out the screw holes...make sure it is a massonary drill bit...this is the best way I have found to make side blow holes in windows without cracking them...make sure you do not screw the fan in too tight or you will crack the window...doing it this way also leaves a perfect hole that looks professinally installed...
May 10th, 2003, 03:31 AM #4
Intake for sure.
PyroSamaJOIN [FaD] | TEAM NUMBER 2037 | http://www.techimo.com/forum/t121132.html
That's hilarious GZ! Nothing like a little controversy to get people stirred-up. This will be fun to watch :)
Xbox One Announced
