December 14th, 2001, 07:47 PM
| The Nebish Jurist
DSJ:
Unless the volcano is designed to produce heat  I'd think it's got to be better than stock!
I would spend the $6.00... again, at $6.00, is there a problem with that HS? Hmm...
If you're really concerned, try the stock, and if it doesn't work to your satisfaction, invest the $6.00 you have along with 10-30 dollars more and purchase a very good HSF. You're trying to protect a pretty valuable component (CPU). I wouldn't skimp on that protection, ya know?
Good luck!
Brangwen  |
