Lapping of heatsink / Mobo Fan Header
Currently Active Users: 1964
Discussions: 200,992, Posts: 2,379,905, Members: 246,360
Old December 13th, 2001, 05:23 PM   Digg it!   #1 (permalink)
woodbutcher's Avatar
Seasons Greetings
Is lapping of the heatsink on a volcano 6 cu+ a good idea?I've read that it should increase thermo conductivity but this unit has a raised copper disc. Also what is safe as far as wattage / amps on a hsf connected to the mobo fan header. This is a 7000 rpm unit and the label on top of the fan only has the thermaltake logo on it with no wattage or amp info.
Thanks in advance WB
woodbutcher is offline   Reply With Quote
Old December 13th, 2001, 06:00 PM     #2 (permalink)
The Mad Redhatter
storm2k's Avatar
Send a message via ICQ to storm2k Send a message via AIM to storm2k Send a message via MSN to storm2k Send a message via Yahoo to storm2k
your wattage should be fine. don't worry, most newer mobos can handle the power needs of a powerful fan, especially when they're on athlon boards.
storm2k is offline   Reply With Quote
Old December 17th, 2001, 02:14 PM     #3 (permalink)
Target's Avatar
Personally, I think lapping is always a good idea....but it really depends on the quality of the surface to begin with.
A lot of heatsink manufacturers don't take the time (ie: expense) to make their surfaces as good as you can get them with lapping. Some do, but its rare in my opinion.
Depending on how smooth and flat it is now, you may or may not see a big difference after lapping. Bottom line is though that unless done incorrectly, you will either see a benefit or no change from what you have now....so you're not really out anything but the time.
As for the fan, keep in mind that some of the higher RMP units draw more power from the motherboard fan headers than they were rated to handle. Most newer ones are able to accomodate the high RMP, high current fans, but some are not and can lead to burning out the fan header on the motherboard. If you can, find out what the fan draws, and what your motherboard headers are built for. If in doubt, it might be wise to get an adapter and run it off the power leads from the powersupply instead just to avoid problems.
Through the NIC, on the cat5, off the gateway router, out the cable modem...….nothin' but net.
Target is offline   Reply With Quote
Is It Just Me? (3083)
Health Care Rationing (14)
Delete an OS (17)
Nvidia GTX 260 problem (10)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
Internet Lost (5)
Foxconn Blackops x48 MoBo (4)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
