August 27th, 2003, 01:18 AM
I got a p4 @ 2.53ghz and the asus pc probe that came with my motherboard says it is at 39c/102f now what I gather it that this is an ok temperature and the pc probes my not be always be acurate but what temperature should I start to worry. the fan is the one that came with the processor and it is not overclocked. |
August 27th, 2003, 01:34 AM
| | Guest
Start to worry if it gets to be 50C Idle like my CPU runs at !!! |
August 27th, 2003, 01:44 AM
| | Spider pig
That's a good temp for that proc. Don't trust the probes entirely though, their not always accurate as you stated. |
August 28th, 2003, 09:23 PM
i just installed the mobomonitor and found out that my cpu temp is running at 79c  ... i really need to do something about it. here's my spec...
athlon xp 2000+
ecs l7s7a2 wd oem hsf
i already got fans installed on my casing..
August 28th, 2003, 09:27 PM
get a better hsf... or make sure its seated properly |
August 28th, 2003, 09:49 PM
eryk, that's what im planning to do after i check the contact between my processor and hsf. |
August 29th, 2003, 12:05 AM
| | Spider pig
Yeah that temperature is a guarenteed crash-fest. Get a nice loud HSF and your good, be sure to put a thin layer of AS3 on the core. |
August 31st, 2003, 08:33 PM
i double checked the settings on mbm and i think i got confused with the config. the 79c that i thought was my cpu was actually my board or heat inside the case. when i played with the settings mbm was able to detect my cpu sensor and it read 49c but after i rebooted the system mbm wont read it again. im planning to instal speedfan and see how it goes...
thanks guys... |
August 31st, 2003, 08:37 PM
Remember you can't run multiple programs for temperature detection at the same time ... it corrupts the temperatures.
Your case couldn't have been running at 79c...that is HOT and would likely put the CPU well over boiling temperature (water)
August 31st, 2003, 09:48 PM
I have a new P4 2.4c Ghz in an ABIT IS7. Stock Intel fan and heatsink, no overclocking, and 2 case fans, plus a hard drive cooler. On idle, my cpu temps are 49C, and rarely rise above 53 when in full use. I've run Winbond and Sandra (independently) and they both give the same readings. I'm ordering round cables for my 2 hard drives, floppy, and my 2 CD players (DVD & burner). I assume my temps are okay. My old P3 800eb ran about 10 degrees lower. Any comments?
Robert
"The philosphy of one century is the common sense of the next"
