January 3rd, 2002, 09:14 AM #1
Newer 7000rpm fans are not as bad as the GW Screamer was...
The Globalwin 7000rpm Screamer emitted a high-pitched whine....it was so bad i had to get rid of mine and my friend covered his case with his quilt....
I have a volcano 6cu+ and the 7,000rpm fan on it hardly sounds like the globalwin screamer... they have much improved the deisng of 7000rpm fans....
But man the FOP-38 made your ears bleed....- Freaky
January 3rd, 2002, 09:26 AM #2
You're absolutely right about the FOP38, I have one screaming right next to me at the moment. My most recent build I opted to trade off a few degrees of core temp for some quiet just to avoid that.
I wonder if you got lucky or whether Delta finally fixed that 'bearing whine" problem?There's only two things in life. But I forget what they are.
January 3rd, 2002, 09:27 AM #3Guest
jeese -I already got ringing in my ears most of the time from heavy handguns and not enough hearing protection - that would drive me mad.
any way to keep the noise down - or is it a design thingy.
wiz
January 3rd, 2002, 03:28 PM #4
Sheesh if you think the cu+ is quirt I would hate to hear the globalwin.
Nope, I refuse to have a signature
January 3rd, 2002, 03:40 PM #5
My brother just got a 6Cu+..says it sounds like a hairdrier! Luckily, my 5000RPM 6Cu keeps mine cool enough!
January 3rd, 2002, 06:42 PM #6
I refuse to use loud, high speed fans. You shouldn't have to shout to be able to communicate with another person with a computer in the room.
I'm currently using a 3" fan running at 2400 RPM. It manages to keep my CPU at a reasonable 44C.
January 3rd, 2002, 08:03 PM #7
7000RPM Fans
Before the Thermaltake Volcano 6Cu+, I had a Vantec CCK-6035D (An All-Copper Heatsink). The Delta Fan was just PLAIN LOUD. It really bothered my parents while they are sleeping. Usually, with this HSF, when I ran Scandisk under Real-Mode DOS, my mom complained about the noise of the Vantec CCK.
When I replaced the Vantec CCK's Stock Delta Fan with a YS-Tech, it was still LOUD. I can even hear it at the Kitchen.
When I got the Thermaltake Volcano 6Cu+, it was sort of loud, but it's not as loud as the Delta and YS-Tech Fans. I did a test-run of the Thermaltake Volcano 6Cu+ with my bedroom's door closed (which houses my AMD-Powered Mini-Tower) and standing inside my parents' bedroom for a few minutes. As opposed to the 7000RPM Delta, the Thermaltake Volcano 6Cu+ was much quieter, although I would've made things quieter with the Volcano 6Cu instead (The Volcano 6Cu+ is more suitable for Athlons, while the Volcano 6Cu is suitable for Durons, but both are AMD-approved fans, although I have yet to see Volcano 7 on the AMD-Approved list).
Using Antec Reference Thermal Compound and the Thermaltake Volcano 6 with Asus Probe PC Health Monitoring Software, the Athlon XP 1600+ I'm using as of this post is now at 46 Degrees Celcius. The highest RPMs I've hit was 7105.
January 4th, 2002, 07:34 AM #8
The 7k fan on the volcano 6 cu+ is not a delta or YS-tech fan. IT's an everflow fan, it's actually louder than the 6800rpm delta/YS-tech however it's a constant burring sound, the delta's fans were high-pitched and quite irritating....I can't say I've used a YS-tech fan however.
January 4th, 2002, 11:28 AM #9Guest
I tie-wrapped a 80mm case fan to my FOP-38. Now I just hear the 92mm case fans instead and they are nowhere near as loud. In the middle of the night I could here that delta screaming on the other side of the house!
January 4th, 2002, 11:36 AM #10
I have a delta 7000rpm screaming next to me now as I type this message... I've gotten used to it! LOL
January 4th, 2002, 11:50 AM #11
My case fans are louder than my Volcano II fan. At night I turn the one in the front and one of the ones in the back off so I can sleep.
January 7th, 2002, 06:03 PM #12Same hereI have a delta 7000rpm screaming next to me now as I type this message... I've gotten used to it!
I got Delta 7000rpm fan on my Vantec HS/F ... it does it's job very well, I was even able to disconnect all my other case fans (5), but the noise ... I cry when I see those mighty P4 Socket478 fans, I can hardly hear them
R
January 7th, 2002, 08:23 PM #13
Got used to my Delta7000 on a GlobalWin WBK32 hs. Of course, I really can't hear it because of the 90mm case fans.
January 7th, 2002, 10:28 PM #14
Had a globalwin 7000 RPM (on WBK38) it was like a dentists office, a high pitch almost drilling noise, I replaced that with a thermaltake 4550 rpm lost 2c on my temps, but I've sorta gained back what little sanity I have. =]
very low noise, my 2 thermaltake 92's over power that sound no probs.
January 8th, 2002, 12:49 AM #15I heard that NDC! I’ve gotten used to mine also. Actually I didn’t hear that……I just plain can’t hear anymore.Originally posted by NDC
J/K
Globalwin WBK38 Hair Dryer on an AMDxp 1600.
Really irritated me at first, guess I got immune.
Mike
January 8th, 2002, 12:58 AM #16Junior Member
- Jan 2002
- Location
- Wazzzzup!!
- 29
Hey, i got it the worst. I got a 120mm fan in there, plus two Volcano 6cu+ on my dual board. Sounds like a goddamn twin jet engine startin up...
January 8th, 2002, 01:09 AM #17Junior Member
- Jan 2002
- Location
- Wazzzzup!!
- 29
January 8th, 2002, 01:40 AM #18
i have a tt 6cu+ and its freakin loud compared to my previous system. its on a xp 1700 runnin at 1800 (1.54) and its peaks at 40 c now that i fixed some case airflow problems. before it peaked at 45 to 48 stock. its loud but my music is louder.
-JOSH H2OL-
January 8th, 2002, 01:55 AM #19
of course, the noise is better than your chip burning up, imo, if you overclock a lot! LOL
drojman
January 8th, 2002, 02:14 AM #20
I have the potentially loudest delta of all...the 60x60x38mm, the big TALL one...but i run it at 7 volts, 5000 or so rpm, and as quiet as a FOP-32 with the output of a standard Delta 7000rpm fan.
People like DooG and I are older farts. Hell, he can't even post unless he's asleep. The country is in your hands, Bingo . . .
