Join TechIMO for Free!
Thread Tools
Currently Active Users: 1967
Discussions: 186,591, Posts: 2,226,906, Members: 230,218
Old January 19th, 2004, 02:15 PM   Digg it!   #1 (permalink)
mad1's Avatar
Overclocking system monitoring software.
What is a recommended(free) software to monitor the results while overclocking a computer?I have been checking the bios to see the results.Here is what I am overclocing,
Epox 8KHA+ with a AMD XP1500. I am currently at a XP1800 with the following settings,
Vcore-1.85V
CPU Temp - 45C, up from 42C.
CPU - XP1800, processor is a XP1500.
VDIMM - 2.5, not touched. Should this be changed?
CPU Clock - 143
FSB - 1502MHZ(143X10.5)FSB286
mad1 is offline   Reply With Quote
FREE instant scan
Old January 19th, 2004, 02:23 PM     #2 (permalink)
rpertusio's Avatar
Send a message via AIM to rpertusio
What 'results' are you trying to find?
CPU-Z might give you the info you are looking for (site is a little slow currently)
Or, if you are looking for other statistics, you might like Motherboard Monitor. (I haven't verified if your motherboard works with this program or not..)
- rp
rpertusio is offline   Reply With Quote
Old January 19th, 2004, 02:27 PM     #3 (permalink)
Green-dildo-riding banana
The Real Bingo's Avatar
Send a message via AIM to The Real Bingo Send a message via MSN to The Real Bingo Send a message via Yahoo to The Real Bingo
Also the NVIDIA System Utility will show you how your system is looking. You can change the FSB in there, but I dont know how to keep the settings into the next restart, as I cant access advanced mode.
And as rp said, the Motherboard Monitor is a nice little tool to see your temps, voltage, etc..
Send lawyers, guns and money; the shit has hit the fan.
The Real Bingo is online now   Reply With Quote
Old January 19th, 2004, 02:27 PM     #4 (permalink)
mad1's Avatar
I want to monitor the cpu speed,FSB,Vcore,cpu temp and any other pertiment settings. I want to see how far I can push the system with the current hardware installed. It appears that a CPU clock of 143 is the max setting before it becomes unstable, had a windows startup error but I am running at the moment.
Old January 19th, 2004, 02:32 PM     #5 (permalink)
rpertusio's Avatar
The two utilities I mentioned in my first post should be able to give you the information you require.
I would look at the specs on your RAM. By adding too much voltage to the RAM, you could easily shorten the life considerably. Check the manufacturer's website for the specs on the RAM, and see if it can support up to 2.7v or so.
If your bottleneck is your RAM, the voltage *could* help, but I think that relaxing your memory timings might help even more. Increasing your memory timings (slower delay) could allow your RAM to perform better at higher FSB rates.
- rp
Old January 19th, 2004, 03:20 PM     #6 (permalink)
mad1's Avatar
Nvidia system utility not working?THe program will not open.
Old January 19th, 2004, 03:23 PM     #7 (permalink)
Hmm, sorry about that. I didnt check to see if your motherboard was supported by it. It appears it isnt. Sorry.
Old January 19th, 2004, 03:27 PM     #8 (permalink)
mad1's Avatar
Not your fault, I should have checked. I looked and it is not on the list.Thanks for the link.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (495)
heatsink issue (9)
Word Association!! (1655)
SSD's, RAID, and External Backup (6)
New Mobo (16)
1 internet. 1 house. 3 computer. ho.. (12)
Connected to LAN but unable to use .. (5)
heatsink issue (9)
Which applications are the best.. (3)
1 internet. 1 house. 3 computer.. (12)
Hard Core Overclock (10)
C++ compiler suggestions (2)
Letter Count Array (3)
SSD's, RAID, and External Backu.. (6)
Folderchat: The Holiday thread (113)
FS: New Benny Hill Megaset DVD .. (6)
Computer won't start (2)
