Results 1 to 6 of 6
    Ultimate Member batmeat's Avatar
    2,754
    Water Cooling Advice needed.
    I'm looking into a water cooling setup for my P4 2.8C. Thermaltake and Swiftech have kits, but I think I could build a better/cheaper one. The problem is I don't know what to buy. I'd like to keep it as an internal kit. Can you watercooling fans out there hook me up and tell me what I need to buy to build my own setup, or recommend a good kit for a beginner?
    norml.org thekingofpain's Avatar
    SoCal
    5,434
    You can custom configure one at DangerDen---they will have all you need: http://www.dangerden.com
    (Id go Swiftech myself)
    Look thru here: http://home.ma.rr.com/silverback/
    Member thegladiatorgy's Avatar
    Oct 2002
    Georgetown, Guyana
    383
    Are you going to OC?
    Member phil_monk's Avatar
    Dec 2002
    UK
    271
    Thats a well good site........... i was thinking of geting the Thermaltake one it looks pritty pants thou and im too scared to make one........
    Sep 2003
    PA
    180
    What about the dangerden MAZE4 Power Kit. IS it worth the $200. I am in the same place as batmeat. How hard is it to set up. I am planning on building and dont want to f up my new system because i didnt do someting. What would be a good case to do this in that wont make things look cluttered inside. thanks
    i am plannign on getting the Thermaltake Xaser III Super Tower series but am thinking about changing.
    2,754
    Yes, I plan to O/C
    How come Sour Cream can expire?
