Join TechIMO for Free!
Thread Tools
Currently Active Users: 1820
Discussions: 188,468, Posts: 2,244,152, Members: 232,718
Old February 2nd, 2004, 09:20 PM   Digg it!   #1 (permalink)
Send a message via AIM to FrankieF21
Water Cooling Setup
would this be a good setup for a water cooled system. Anyone suggest some decent water cooling manufaturers. I was looking at danger den. Does the 1/2in tube make a difference. Any good sites that compare these types of things. Any other information is welcome about the topic thanks
note: i am planning on running an A64 and a R9700Pro. Also will have two WD raptors running at 10k RPMs. I know i need a large case for all this. Any sugestions???
FrankieF21 is offline   Reply With Quote
Old February 9th, 2004, 05:43 PM     #2 (permalink)
"Oderint, dum metuant"
no1_vern's Avatar
First thing you need, is to put the pump AFTER the reservoir, not in front of it. The pump needs to TAKE FROM the reservoir, and pump to the CPU, Vid card, then to the hard drives. I dont think having the second radiator is necessary. Just the one before the tank(reservoir) is needed. You need the tank to be unpressurized so you can add water to the system if needed.
Dont use 1/2 tubing unless its free and you are willing to do about half again the amount of work that you would with smaller tubing. 3/8ths is generally preferred. I think 1/2 much too expensive for the amount of cooling you will be doing, and you will run into turning radius problems with 1/2 that you WONT if you use 1/4 or 3/8.
Check out Google results :
http://directory.google.com/Top/Comp...rcooling/?tc=1
HardOCP:
http://www.hardocp.com/article.html?art=Mzkz
Overclockers(article about aquajoe):
http://www.overclockers.com/articles850/
KIT(for ideas, dont buy unless you believe it will do the job):
http://www.aquajoe.com/
Xoxide sales of watercooling cases/kits:
http://www.xoxide.com/watcoolcas1.html
Look and compare then decide what you want to do.
no1_vern is online now   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2992)
Intel Pentium 4 531 (7)
Please don't divorce us (40)
nVidia GTX 295 now available (18)
what new gaming title to buy?! Oh t.. (43)
*TechIMO's Top 30 PCs* (44)
New psu question (1)
Finishing off my first built co.. (4)
AMD Phenom II X4 940 Black Edit.. (11)
Want to Buy a Home, But Can't Q.. (0)
New Build ( Finally ) (10)
Automatic updates turns off aut.. (0)
I think my PSU is dieing (4)
Core 2 Quad Q9550 system (3)
