no need for all that . it is a great cpu hs but it cost way to much . try a vantec areo flow . it is very quite and you can get one shipped for under 25$ . they work very well . i use one in my oc'd 2500 and in the summer , i live in place where 100f isn't abnormal in the summer , it never went over 44c under full load . if your just buying a xp2500 now you might not ever get it to oc to 3200+ speeds . the new cpus are multiplier locked . so instead of over doing it on a hsf combo , remember 50c is not really that hot for an amd cpu , get a good one that will work well .
