Join TechIMO for Free!
Thread Tools
Currently Active Users: 1935
Discussions: 188,468, Posts: 2,244,142, Members: 232,718
Old February 9th, 2004, 07:41 PM   Digg it!   #1 (permalink)
Send a message via AIM to shadyb1
Are these CPU temps okay?
I recently completed my first build and have been monitoring both the CPU and motherboard temps through the BIOS and ASUS PC Probe. They seem a little high for my setup to me:
CPU Idle: 42-46C
Motherboard Idle: 39-43C
CPU Full Load: 49-53C
Motherboard Full Load: 40-44C
Ambient air temp: 80F (Hawaii)
Here's my setup:
ASUS P4S800D
P4 2.8C
1 GB Kingston DDR400
120 GB Maxtor HDD (2)
Radeon 9600 Pro 256MB
NEC 8x DVD-R/+RW
Lite On 52x32x52
Hercules Gamesouround III 7.1
Hauppuage PVR-250 TV Tuner
Antec SX-835 Case w/ 350 watt PSU
5 80mm Sunon case fans
2 fans in PSU
I also have all round cables and the PSU connectors are tied-up to increase air flow. My fans are set up as follows: 2 intake at bottom front, 1 intake over HDD, 2 outtake at top back, and two PSU fans operating correctly.
I'm using the stock HSF. Even so, with all of the case fans, shouldn't the temps be lower, especially at idle?
Are my temps within the satidfactory range? I've read people whose temps were much lower with similar setups.
Would switching the stock HSF make that much of a difference, especially with the motherboard temps?
Any suggestions?
Thanks from a newbie...
shadyb1 is offline   Reply With Quote
Old February 9th, 2004, 07:49 PM     #2 (permalink)
that aint a lightsaber
tony_j15's Avatar
Send a message via ICQ to tony_j15 Send a message via AIM to tony_j15
Since you are in Hawaii, the air temp is a bit higher than usual. 53 at full load is nothing to worry about...sorta. Most people will reccomend keeping the CPU below 50, but damage cannot occur until over 60. Still, I would get a better HS.
tony_j15 is offline   Reply With Quote
Old February 9th, 2004, 07:49 PM     #3 (permalink)
(AKA) Nakamura
sweeper2's Avatar
well, with 80 degree air, I would guess those are ok, but if it was in AC around 72-75 F, I am sure would be alot cooler. My brother runs a pentium, but I run an athlon cpu, his runs around 27C or so. Let's see if anyone else replys and has input...
P4 2.8ghz / MSI 865PE Neo2-PS / Power Color HD 3850 512mb agp / 2gb DDR400 / 320gb SATA Samsung HD
Old February 9th, 2004, 07:54 PM     #4 (permalink)
teengeek88's Avatar
Send a message via AIM to teengeek88 Send a message via Yahoo to teengeek88
stock hs/fans are really cheesy.... get a good one it might cost around $30 but its worth it.... look for one with a copper heatsink and as much CFM as you can get... also notice how loud it is it will be measured in dB's
Welcome to TechIMO
teengeek88 is offline   Reply With Quote
Old February 9th, 2004, 08:16 PM     #5 (permalink)
Thanks for all of the reponses so far.
I had a couple other questions:
If I were to replace the HSF, I'd want to get a good 80mm or 92mm fan which moves a lot of air. Could I still plug the 3-pin connector into the MB fan connector or would it fry the board?
Anyone have any good HSF recommendations (preferably a copper HS)?
Also, would replacing the stock HSF also bring down the MB temperatures significantly, or just the processor?
Thanks...
Old February 9th, 2004, 08:31 PM     #6 (permalink)
Bringing Da Funk
Gait_Keeper's Avatar
Send a message via AIM to Gait_Keeper
I agree 80F room temp, 53 isn't bad at load
keep your machine about 6 inches from the wall so the hot exhaust air doesn't go back in.
think about making a blowhole in the top of your machine, hot air rises, so it will let it out, i cut one and put a 80mm fan there works great!
last but no least turn up the AC
Gait_Keeper is offline   Reply With Quote
Old February 10th, 2004, 03:32 PM     #7 (permalink)
HeadBand's Avatar
yes i dont think you really need a new hsf those temps are fine but if you want to drop the temp a few degrees you might try playing around with the case fans....what is your current setup
Hey who turned sigs on?
Old February 10th, 2004, 04:39 PM     #8 (permalink)
Take off the side panel and leave it off, or do what I do take the side panel off and put a box fan next to the system. On my P42.8c setup I got it down to 75f idle(twenty something C), thats 3f above room temp!
cysus is offline   Reply With Quote
Old February 10th, 2004, 05:30 PM     #9 (permalink)
The Terk's Avatar
Send a message via AIM to The Terk
i dont think anyone has asked about the thermal compound that u are using? what would that be? i would recommend Arctic Silver 3 (AS3) since it does the job pretty well and being mostly silver (there was a news thread about this not too long ago) also, i would recommend the thermaltake silent boost hsf because it pumps out some major cfm and is fairly quiet... also, u can not go wrong with zalman hsf units (NOT THE FLOWER)... the antec TMD hsf is good also.... the list goes on
The Terk
The Terk is offline   Reply With Quote
Old February 10th, 2004, 05:49 PM     #10 (permalink)
Thanks for the suggestions.
As for my fan setup, I have two Sunon 80mm in the front taking air in, one over the hard drive also blowing air in, 2 in the rear blowing air out, and the PSU which is also blowing air out at the top.
I'm using the stock TIM (the stuff on the HS) which came with the processor.
Are the temps high enough where it would be worth it to take out everything and wipe off the TIM, and replace the HSF? Or should I just wait about a year until I upgrade the processor?
Also, what about the motherboard temps? Are they okay and would they go down if the processor temp goes down?
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Intel Pentium 4 531 (7)
Is It Just Me? (2991)
AMD Phenom II X4 940 Black Edition (10)
Please don't divorce us (40)
nVidia GTX 295 now available (18)
what new gaming title to buy?! Oh t.. (43)
building a gaming computer, input p.. (14)
AMD Phenom II X4 940 Black Edit.. (10)
How to rip dvd in fast way - sh.. (0)
Bought the Visiontek Radeon 387.. (0)
black screen (0)
Dell blinking amber light- No b.. (24)
Core 2 Quad Q9550 system (3)
