March 27th, 2004, 06:41 AM
| A small problem (zonealarm)
I got zonealarm, but the problem is, that it dosen't start automatic.
And forget to turn it on sometimes (makes me nervous  ), any ideas, why it dos not start automatic?
~Pamlor |
March 27th, 2004, 06:54 AM
Can you manually put a shortcut to Zone Alarm in your Start up folder and have it auto start?
Cheers!
Beware of promises of life where death is prerequisite.
March 27th, 2004, 07:23 AM
| | may contain mild peril
| Quote:
The last tab sheet 'Configure', contains several configurations of the program itself. These configurations do not have an impact on the security.
Be sure that the 'Load ZoneAlarm at startup' is checked, otherwise ZoneAlarm will not start up automatically with Windows.
| Not sure if this is any use to you, to read it in context click here
Regards
ed |
March 27th, 2004, 07:41 AM
| | ᅟᅠ
I've stopped using Zone Alarm. I've noticed many issues with it from day one. I've started using Kerio Personal Firewall. The lite home version is free for personal use. It seems to run much more smoothly than ZA ever did for me. |
March 27th, 2004, 08:07 AM
What OS are you using? You shouldnt stop using Zone Alarm for one single issue. Unless you are having big problems, and many you should consider changing firewall. I would try Beemer's suggestion, if that doesnt work try uninstalling it, and reinstall it after. If that doesnt do the trick either, try entering 'msconfig' in Run and see if any start up program called Zone Alarm (or similar) is checked, because if its unchecked the program wont start in Windows start up.
dan |
March 27th, 2004, 09:01 AM
There is definitly an option to start it when windows boots. Start zone alarm , go to the overview tab and check the settings. There is a checkbox labeld Load ZA at startup, under "general". It should be checked.
__________________ Buy the ticket, take the ride. - Hunter S. Thompson |
March 27th, 2004, 05:18 PM
