November 18th, 2006, 01:15 PM
| virus problem
if i do a virus scan with sophos anti-virus it comes up with two infected files in the system32 folder with the extension .dll. if i try to delete them through the "manage quarantine items" it tells me that i dont have the rights to perform this action even though i have an admin account and all the sophos options are set to allow me to delete these files. if i go into the system32 folder to try and delete them manually they do not appear, even with "show hidden files and folders" turned on. i tried to copy another file with the same name into the folder and it said the usual "are you sure you want to replace the file" stuff and i click ok and it tells me that there is another file with this name, which i obviously already know but it refuses to let me replace it.
any ideas? |
November 18th, 2006, 01:38 PM
No man's life, liberty, or property are safe while the legislature is in session. --Mark Twain (1866)
December 1st, 2006, 02:11 PM
Ok, i tried to get into safe mode and my computer got stuck in this endless loop of starting up and then flashing up a blue screen for about half a second before restarting and i couldn't get it out of safemode so i tried repairing windows but it said that it couldn't because it was in safe mode so in the end i had to reinstall windows but thanks for the suggestion anyway. |
December 1st, 2006, 02:26 PM
Glad to see you are all sorted.
That sounded like a nasty problem, when it denied you access to safemode.  |
December 1st, 2006, 03:01 PM
| | 分かりますか。
You were proly better off ReInstalling anyways with a virus like that.... ;-p |
| You may post new threads You may post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Virus problem!?!? | s2cmpugh | Technical Support | 12 | April 30th, 2005 07:30 PM | | Virus Problem | cyclist110 | Applications and Operating Systems | 9 | November 25th, 2004 02:02 PM | | cd and virus problem | mysundown1305 | Applications and Operating Systems | 7 | September 27th, 2004 10:31 PM | | virus problem | mossopinc | Applications and Operating Systems | 6 | May 7th, 2003 02:45 AM | | Possible virus problem? | Sixpac_XP | Technical Support | 4 | January 31st, 2003 07:10 PM | | Most Active Discussions | | | | | Recent Discussions  | | | | | |
