Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Security and Privacy Issues
Virus Problem?
Currently Active Users: 2142
Discussions: 200,959, Posts: 2,379,531, Members: 246,329
Old February 14th, 2009, 08:04 PM   Digg it!   #1 (permalink)
Virus Problem?
After turning on a friends computer it loaded up XP no problem but then a
pop-up comes up with an IE window (even tho default browser is Firefox) and an error message comes up over the IE window saying that "the address cannot be located" or words to that effect.
When I tried to close the error message, the IE window remains and another pop-up IE window comes up over it with the same error message over that. This seems to go on forever, with a (presumabely infinite) number of pop-up IE windows, all the same.
The only way I could get rid of all these pop-ups is to hold Alt-F4 down and
then, after a sequence of another half dozen of these pop-ups, they all delete and disappear.
The only virus program running was Avira. I did a scan with it and it didn't
show anything but then I noticed that the virus database hadn't been updated for about 3 months.
I tried updating the virus database over the internet but it couldn't access
the update sites, even though Firefox seemed to work Ok.
I deleted Avira and loaded Eset to do a thorough scan but found that all communications seemed to have frozen. Firefox runs but can't contact any
sites. Eset can't update it's virus vault and Spybot, which I also tried
loading, couldn't download it's necessary files.
When I look at the network connection in the Control Panel it says it is connected ok but the "packets up" freezes on about 70 and the packets down freezes on about 5.
I tried loading the latest AVG Free off a flash drive with the computer in Safe Mode but AVG failed to load.
Can anybody please help me?
elkatman is offline   Reply With Quote
Old March 19th, 2009, 10:31 AM     #2 (permalink)
Banned
It seems that your computer is badly infected from viruses and malwares,spywares.
You can follow these troubleshooting steps:
1. Scan your computer by using any updated antivirus program.
2. Try to install and download the "Antimalwarebytes" (freely available)
3. Try to update "Antimalwarebytes".
4. Scan your computer using the "Antimalwarebytes".
5. Follow the same procedure for "SuperAntiSpyware" as you done for "Antimalwarebytes".
6. Delete all the internet temproray files.
techservices24 is offline   Reply With Quote
virus problem wingman6191 Security and Privacy Issues 4 December 1st, 2006 03:01 PM
Virus problem!?!? s2cmpugh Technical Support 12 April 30th, 2005 07:30 PM
Virus Problem cyclist110 Applications and Operating Systems 9 November 25th, 2004 02:02 PM
cd and virus problem mysundown1305 Applications and Operating Systems 7 September 27th, 2004 10:31 PM
Virus problem GohanSSJ General Tech Discussion 17 January 5th, 2003 10:30 PM
Is It Just Me? (2969)
The disrespect of Obama by Russian .. (42)
Making Health Care Worse (179)
Print spooler problem (16)
Nvidia GTX 260 problem (0)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
