Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Security and Privacy Issues
PC constantly rebooting and other problems
Currently Active Users: 1493
Discussions: 200,930, Posts: 2,379,154, Members: 246,296
Old August 13th, 2009, 08:08 AM   Digg it!   #1 (permalink)
Hello, I have unfortunately been infected with the Braviax virus. I had managed to find and kill the process and deleted the files associated with it and ran a scan using my McAfee antivirus, but as I later found out it reinstalls itself which it did whilst my OH was using the pc.
He sat with this running for about an hour, connected to the net and now I have a pc that won't connnect to the internet, is asking me to reactivate Windows XP but won't do so and when in safe mode after about 2 minutes it displays an error message stating
This system is shutting down. Shutdown initiated by NT Authority/System
C:\Windows\System 32\services.exe terminated unexpectedly with status code -1073741819. The system will now shut down
which it does and then restarts itself. A friend has tried to run combofix on it but as i can't connect to the internet it is impossible to do this. Have tried to restore to a previous point but there are no available points to restore to. Can anyone help???
Morrigan is offline   Reply With Quote
Old August 14th, 2009, 03:29 PM     #2 (permalink)
My best advice is try creating an Ultimate boot cd 4 windows at a friends house and using its tools to try and clean the virus. Your other option is backup important documents and reformat your computer and reinstall windows. Option 2 is easier and ultimatley what i would do.
bobreaze is offline   Reply With Quote
PC constantly freezes designosaur Technical Support 45 February 21st, 2005 12:37 PM
constantly asking for dsiks sectshun8 Applications and Operating Systems 3 January 27th, 2005 11:34 PM
IE crashing constantly kendy Technical Support 4 August 3rd, 2004 03:12 PM
HELP!! Rebooting constantly!!! GhostPoet General Tech Discussion 38 March 25th, 2004 05:39 PM
computer constantly shutting off franklinz Technical Support 3 November 17th, 2002 03:42 PM
Is It Just Me? (2870)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
