Results 1 to 5 of 5
    Member Sanman's Avatar
    Tilton,NH
    365
    Zone Alarm problems
    I keep getting error messages when trying to do anything with ZA. My son was messing around with my PC and screwed it up. Now I get an error message saying "validation failed" I can't uninstall it or reinstall it. I can still view web pages for a period of time until it restricts internet access.
    Since I have gone from cable back to free access via Netzero dial-up I have no use for a firewall anymore so I need to get rid of it but it won't let me. Can anyone help me? I am using Win 98SE
    Ultimate Member Droppyale's Avatar
    Dec 2002
    1,964
    well if it was me, I would still use ZA even with dial up.
    why don't you try re-installing it.
    that should fix the problem.
    Tilton,NH
    365
    I have tried to several times to reinstall. I get
    "validation failed for C:\Windows\Temp\VSUTIL.DLL"
    Mar 2002
    Under Your Bed
    8,909
    Re: Zone Alarm problems
    Come on Droppy, you can do better than that!
    Have you tried totally cleaning out your Temp files before attempting the reinstall?
    Also, try downloading another VSUTIL.dll file from this site.
    VSUTIL.dll Error Information
    Zone Alarm Uninstall/Reinstall FAQ
    Mike
    Ultimate Member Starfury_2260's Avatar
    Aug 2003
    KY
    1,463
    you need a firewall no matter what kind of connection you have. you're just as vulnerable.
