Okay my sisters vaio pcv rx741 came with two partitions, c and d. The C is 15 gb and the D is 45 gb. I dont know why D is bigger but whatever. Okay, so she ran out of room so I thought I would run the system recovery disks and just delete the partitions but the program makes you keep both partitions and will only let you set the C drive from like 8 gb to 30 gb, no larger. So Im kinda stuck.
I had a Sony Vaio pcv 640. The Sonys are VERY proprietary. Have
you tried to change the partition through the disk manager?
If that does not work you just might be stuck.
