System having problem detecting hard drive
Currently Active Users: 1613
Discussions: 200,925, Posts: 2,379,128, Members: 246,291
Old May 1st, 2004, 02:16 PM   Digg it!   #1 (permalink)
Angry
Hi... i have just bought a Western Digital Enhanced IDE 80GB Hard drive as a add on drive. When i installed into my system, my com detected the drive and updated the bios automatically. but when i enter windows, in "my computer", it does not reflect the drive. Under "System properties", "Device manager", "Disk drive", there is a new input, "Generic IDE Disk type 02". But there is no drive letter assigned to it. I do not know how to do it. The jumpers and cable settings for slave and masters were installed correctly. Can it be due to my system motherboard being too old? if so, how do i solve the problem?
my current system specs:
COMPAQ PRESARIO 5170
Quantum Bigfoot 6GB (master)
Western Digital 80GB (intended slave)
pentium II 350MHz
Windows 98
320MB RAM
Please help me.... my current hard drive have only bout 400MB of free space left..... extremely low... so i really need this hard drive to be working....
Thanks in advance to those kind souls...
marktan1 is offline   Reply With Quote
Old May 1st, 2004, 02:26 PM     #2 (permalink)
Jarhed7276's Avatar
It sounds like you need to partition and format the drive.
IN Win98 use the fdisk and format command.
Use fdisk to create logical partitions. Then use the format command to format the drives.
When you use the fdisk command make sure you are partitioning the slave drive otherwise you will erase your master drive.
Jarhed7276 is offline   Reply With Quote
Old May 2nd, 2004, 08:28 AM     #3 (permalink)
i tried. there was no drive letter assigned to it. so when i use the command, which drive should i refer fdisk to?
Old May 2nd, 2004, 09:40 AM     #4 (permalink)
dusty825's Avatar
Send a message via AIM to dusty825
Just click on the drive, right click and a box of options will come up. Click on the format one.
Lifes too short to drink cheap beer
dusty825 is offline   Reply With Quote
Old May 2nd, 2004, 09:51 AM     #5 (permalink)
Supporting our military
Bill in SD, CA's Avatar
Did you use the floppy disk that came with the drive to try the partition and format?
If not, boot from that floppy and it will more than likely detect both drives.
Make sure you choose the right drive.
Hard Disk Setup - Partition and Format
Bill
Bill in SD, CA is offline   Reply With Quote
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
