Secondary IDE Problem
Currently Active Users: 2547
Discussions: 200,996, Posts: 2,379,944, Members: 246,364
Old August 5th, 2004, 11:15 PM   Digg it!   #1 (permalink)
I want my computer to have 2 Hard Drive’s and 2 CD-Rom's. I placed the 2 Hard Drive’s on the Primary IDE Connection and set the jumper on my primary drive to Master and the secondary drive to slave. Then I connected the 2 CD-Rom's to the Secondary IDE Connection and set my CD-Rom as Secondary primary and my CD-RW as my Secondary Slave.
My Secondary Connection has never been used before this attempt.
I booted up and went into my BIOS and it detected my hard drives on the primary connection but it didn’t detect the secondary drives at all. I looked around for a place in my bios to maybe enable the Secondary IDE but came up empty.
So I was wondering what is going on? Is the Secondary IDE dead? Is there a way to correct this?
VaioViper is offline   Reply With Quote
Old August 5th, 2004, 11:28 PM     #2 (permalink)
LeftCoast's Avatar
You may want to try updating the IDE drivers, from the manufacturer's site.
Millions long for immortality who don't know what to do with themselves on a rainy Sunday afternoon.
Susan Ertz
LeftCoast is offline   Reply With Quote
Old August 5th, 2004, 11:34 PM     #3 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
Typically the bios does not recognize CD drives the same way it does for hard drives. As long as you have the secondary ide channel enabled (should be somewhere in your bios there or maybe it's always enabled) you should be fine. Windows should recognize the CD drives and list them in the Device Manager.
OuTpaTienT is offline   Reply With Quote
Old August 5th, 2004, 11:52 PM     #4 (permalink)
I prefer to have the burner as the primary.....
check in the device manager and see if the drives show up
in the bios it may not auto detect the cd-drives...sometimes you may have to set the secondary pri and slave to "cd-rom"
Old August 5th, 2004, 11:59 PM     #5 (permalink)
1010011010
jmichna's Avatar
Could also be something as simple as a bad data cable for those secondary IDE devices, especially if not detected in BIOS. Is the cable connected properly, and fully seated at the two opticals, and at the mobo connector?
If you temporarily remove the two opticals, and connect your second HD to the second IDE channel, does it get detected?
jmichna is offline   Reply With Quote
Old August 6th, 2004, 12:02 AM     #6 (permalink)
LeftCoast's Avatar
Dell seems to do it differently, as every computer I've ordered thruogh them has the cd-rom od dvd-rom as the master. i didn't think it ever mattered, but since noticing this, I've followed suit...
Old August 6th, 2004, 12:07 AM     #7 (permalink)
Well they probably sell more comps with just the cdrom or DVD as opposed to 2 drives...so they probably just build everything with the cdrom or dvd in position one and then add other drives as necessary.
I have always understood it that the primary drives gets some priority over the other drive so I would put the burner there...of course if one watched lots of dvds and only burned cds once in a while it might pay to have the dvd on as primary.
Then again, with the speed of things today it probably doesnt matter much either way, lol
PIO mode? why.. is should be DMA! Help! Sixpac_XP Motherboards 18 January 29th, 2009 01:14 AM
How to hook up CDs and HDs Armadel General Tech Discussion 14 April 21st, 2004 03:07 PM
Forcing DMA transfer mode VeryTired Technical Support 12 February 28th, 2004 12:16 AM
CD-RW XP COMPATIBILITY HELL!!!!!! FunkyM Technical Support 27 November 1st, 2002 04:13 AM
Missing drive letter "E" ZENYO General Tech Discussion 30 January 11th, 2002 03:28 PM
Is It Just Me? (3092)
Foxconn Blackops x48 MoBo (5)
Health Care Rationing (16)
Nvidia GTX 260 problem (14)
Delete an OS (17)
Laptop with wireless problem. (13)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
add ram to existing (0)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
