Results 1 to 3 of 3
    Ultimate Member amdkt7's Avatar
    Nashville, TN
    1,942
    Speeddisk32 results and drive temps
    Here is my results using Speeddisk32 on my Maxtor D740X-6L 20 gig 7k rpm drive.
    This system is Abit KT7 with 1Gig Athlon, 128meg ram
    Also my drive temp is running 50c.
    Attached Thumbnails Attached Thumbnails Speeddisk32 results and drive temps-max.jpg
    Ultimate Member Richard Cranium's Avatar
    Dahlonega Ga
    8,282
    MAN, that is a FAST drive !
    Your temps seem too high, if the thing is too hot to touch you better get some cooling on it and fast.
    I've had some odd speed readings.
    http://www.techimo.com/forum/t12256.html
    On a WD 20g 7200 ATA/100 in a 1998 Dell Pentium II 350
    the WD 20g 7200 showed 9k/sec and less
    the WD 4.3 5400 drive showed 12k ~ ?????
    this is much faster than the 7200 ?
    A check of Device Mgr showed DMA enabled, the WD utility to enable ATA 33/66/100 FAILED !
    I installed a Iwill Side-66 RAID card and ran it as a single drive and got readings from 4.0k-31,000
    The blue bar was 2" wide ??
    What gives ?
    Nashville, TN
    1,942
    My drives are quite warm to the touch, but I think it's ok. I need to take that utilty home and test it there also.
    Sounds like you are not getting your drives setup right, perhaps your machine has a problem, incorrect or incorrectly installed drivers?
    You are using the 80 conductor cable. Did you use the cable select settings on the drive? Some drives will not operate at ATA66+ unless the jumper is on cable select.
