Join TechIMO for Free!
Thread Tools
Currently Active Users: 1606
Discussions: 186,731, Posts: 2,228,343, Members: 230,391
Old November 6th, 2004, 01:04 PM   Digg it!   #1 (permalink)
Problems with Prolific 3507 firewire/USB combo drive
I am running a laptop with WinXP Pro SP2 and have been having problem with a Speeze enclosure using the Prolific 3507 combo controller. I have tested it extensively with large video files that I was working on in Premiere and found it to corrupt the NTFS partition information when connected via firewire. I could not recover the partition table when this happened I recovered the data using GetDataBack for NTFS and reformatted the drive. This has happened 3 times using the firewire interface, and seems to happen under extensive IO operations. Since, I have formatted again and am using USB 2.0. It has not had any problems yet though it is a little slower with this interface.
I have searched all over the net and can't find a solution to this. I also have a TDK Indi DVD writer connected through firewire and that hasn't been a problem.
The drive is a WD 200GB 7200 rpm.
Matt_D is offline   Reply With Quote
FREE instant scan
Old January 3rd, 2005, 01:13 PM     #2 (permalink)
similar problem with Plumax PM-525C2-PPS and -PPB
I have a very similar problem with Plumax PM-525C2-PPS and -PPB combo USB 2.0 & Firewire 1394 external enclosures. These enclosures use the Prolific 3507 combo controller. The problem is that when connected to the computer using the Firewire interface, the boot sectors and perhaps other sectors of all of the partitions on the hard drive eventually get trashed. The partition table on the drive seems to be OK. It is just all of the partitions that are trashed. This has happened twice for me. The first time I used GetDataBack to get most of my data back from the five partitions that were trashed on a 40GB Maxtor disk. I reformatted all of the partitions and reconnected the disk using the USB interface instead, and it has been OK for two months. After that fiasco, as a test, I hooked up a different disk that I have a complete backup of in a PM-525C2-PPS using Firewire. This disk contains only files that I read, that is, I have not written to the disk. Well, yesterday, the second disk suffered the same failure. The boot sector was trashed. I used GetDataBack again and was able to recover all files except files in the root directory. So whatever trashing is occurring seems to affect more than just the boot sector. The recovered files compared 99.999% the same as the files in my backup. There were just a couple of unexplainable discrepancies.
My solution for now is to avoid using the Plumax PM-525C2-PPS and -PPB for critical data and stop using their Firewire interface. I added another bank of USB 2.0 ports to my PC so I can use the USB interface.
The sad thing is that I could have purchased nearly identical enclosures using the Oxford 911 chip for just $5 each more than the cost of the defective ones. Anyone considering purchase of the defective Plumax PM-525C2-PPS and -PPB should instead consider Plumax PM-525C2-PTS and -PTB which are advertised as using the Oxford 911. I have not heard of any data loss problems associated with the Oxford chip. All four of these enclosures are available from http://www.dealsonic.com/ which is where I purchased the defective enclosures. I had no problems with the purchase - just a bad choice of product to buy on my part. I would purchase from them again.
Roy
royfl is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Help!! Windows isnt installing eminem_rh25 General Tech Discussion 15 September 29th, 2004 06:57 AM
Busted cd drive? cd comes out on tray spinning! QCompson Technical Support 4 March 19th, 2004 03:21 AM
p4 2.5 or Duron 1.8 Rand Dusing General Tech Discussion 16 November 29th, 2003 01:58 PM
SOLDIERS NEED QUICK DVD-/+RW SUGGESTIONS? inzzane Technical Support 13 July 5th, 2003 05:06 AM
Problems With Geforce 2 Mx200 lock ups soulja Graphics Cards and Displays 41 April 23rd, 2003 01:28 AM
Is It Just Me? (750)
Newegg WARS!!! (55)
Best graphics card for around $600 (8)
E5200 15.2GHZ?? (12)
Car Talk! (8693)
Folderchat: The Holiday thread (159)
New info on the Phenom II X4 (46)
Best Boot Drive Imaging Software (17)
Bought an AGP "HIS Radeon HD 3.. (21)
Service Pack 3 (4)
replacing tvs msp345 printer he.. (1)
LCD monitor sizes and wide scre.. (4)
Should I build my computer arou.. (0)
Computer won't start (15)
Best graphics card for around $.. (8)
Logitech Mx 3200? (1)
