I've installed a IDE raid card (skymaster ATA133 RAID controller Silicon Image chipset) with 4x 40GB PATA attached, and
a 120GB on primary master IDE with NO OS only data,
a DVD drive on primary slave,
a DVD writer on secondary master,
now, when I first boot, I set the raid bios as raid 0+1, the raid bios accepts, then after reset the system is not booting neither for win xp CD from the optical drives nor the raid HDD.
so do I have to reassign IRQs from the bios?
or need to flash the original motherboard bios? (I am using ASUS P4XP-X mobo)
or is any of setup is wrong?
can anyone pls help with the correct procedure for installing IDE raid 0+1? cos the manual from raid card doesnt tell me anything!
