Join TechIMO for Free!
Thread Tools
Currently Active Users: 3508
Discussions: 188,430, Posts: 2,243,843, Members: 232,676
Old December 9th, 2004, 11:51 PM   Digg it!   #1 (permalink)
ghost problem
ok so i have 2 HDs one is a maxtor sata the other is a western digatal EIDE, anyway i ghosted the eide to the sata but when i un pluggeed the eide and tried to boot off of the sata it worked fine, much faster than usual, but as soon as it got to the 2nd windows xp loading screen, the one right before you see the welcome screen, it just says windows xp, no loading welcome screen or anything like that
any ideas to try
or any more required info?
thanks in advance
newcomp is offline   Reply With Quote
Old December 10th, 2004, 12:20 AM     #2 (permalink)
Super F@D Folder
windows dosen't have the sata drivers in it, so it won't boot is probably what your problem is sucks. only way i can think that may...stress may get around that is to put it on the eide drive and boot it with the sata drive in it, then install the sata drive in windows...so that it'll have the drivers. and then ghost after that. That's my guess..i doubt that'll fix it but it may....hope it does .
Old December 10th, 2004, 12:27 AM     #3 (permalink)
i think the sata drive is installed becase when i am in windows i can use at as a drive it works fine. i just cant boot all of the way
Old December 10th, 2004, 12:32 AM     #4 (permalink)
ok i got this error are any of these files important
Old December 10th, 2004, 12:46 AM     #5 (permalink)
Did you try Google yet?
Siliconjunkie's Avatar
Send a message via AIM to Siliconjunkie
Just like it said, they will all be recreated.
hiberfile.sys is for hibernation and will be recreated.
pagefile.sys is the pagefile and will be recreated.
The others are just logs, wouldn't worry.
The probem is more likely that windows does not have everything it needs at boot time, but does at runtime.
Siliconjunkie is offline   Reply With Quote
Old December 10th, 2004, 12:55 AM     #6 (permalink)
ok turned off welcome screen and fast user switching, now it gets all the way to login but then when i type password and hit enter it starts to go then after about 2 seconds it switchis the dialauge to logging off and stays that way
Old December 11th, 2004, 02:49 PM     #7 (permalink)
sechs's Avatar
You booted the machine with both the source and clone drive in it. Windows reassigned the volume GUID to the serial ATA drive. Windows can now no longer identify the drive from which to read some system files.
Solution: Re-image the serial ATA drive from the original. Remove the original. Then, finally, attempt to boot from the serial ATA drive.
sechs is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Aborted Image Creation with Norton GHOST Doug_SS Technical Support 7 June 4th, 2003 03:43 AM
I could use some info on Ghost cat1947 Storage Related 6 December 3rd, 2002 08:37 PM
Ghost and Windows XP.... FalcomPSX Storage Related 23 October 30th, 2002 11:08 AM
No Audio Lateralus Technical Support 8 March 5th, 2002 10:32 PM
Is It Just Me? (2964)
can anyone help me? (5)
building a gaming computer, input p.. (11)
How to increase my ram? (14)
Folderchat Weekday thread (444)
New Build ( Finally ) (8)
CPU wont boot (8)
RCA 52Inch HDTV wont turn on (6)
Outlook 2007 contact management (1)
What is L2 Cache??? (2)
what new gaming title to buy?! .. (39)
system restore 'next' button wo.. (16)
Avatars (32)
AOL address book problem (9)
Scanner will not work (1)
Finishing off my first built co.. (0)
building a gaming computer, inp.. (11)
Core 2 Quad Q9550 system (3)
