philips dvd8421 and dvd+r DL problem
Currently Active Users: 2238
Discussions: 200,944, Posts: 2,379,347, Members: 246,306
Old March 1st, 2005, 10:42 PM   Digg it!   #1 (permalink)
I have an HP pavillion a735w that has a philips dvd8421 dvd+r/+rw dual layer drive in it. I bought some verbatim dvd+r dl blank discs, and when I tried to record on one, it told me "in-compatible media".
I tried updating the firmware on it, but it still will not recognize these discs. Are there certain discs that it will recognize, and others it will not?
There are not too many types of dvd+r dl discs available here.
I have even debated buying a plextor drive, or one that is perhaps more compatible. Any ideas?
Caddyman
caddyman is offline   Reply With Quote
Old March 2nd, 2005, 02:32 PM     #2 (permalink)
Media
Sometimes certain DVD's just will not work. All media (even unbranded) has a little number written round the middle hole, take that number and put it into google, that will let you identify it, then check with your hardware vendor if it is complient or not.
If you can buy DVD media from a local hardware store individualy, buy several types, and find one thats good for your drive, i find Ritek are the best for me.
thelonegunman is offline   Reply With Quote
philips dvd8421 and dvd+r dl problems caddyman Technical Support 0 February 28th, 2005 10:35 PM
DVD burner Germain Technical Support 5 February 10th, 2005 11:20 PM
Sound problem!!! Argh!! Micro Bean Technical Support 20 December 20th, 2004 04:15 AM
i crawled into a cave part 2 newcomp Storage Related 3 December 6th, 2004 05:55 PM
Laptop - Numerous Problems Midd_Knight Technical Support 5 November 11th, 2004 02:15 PM
Making Health Care Worse (163)
The disrespect of Obama by Russian .. (17)
Is It Just Me? (2920)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (2)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
