DVD wont read DVDR  | | |
May 22nd, 2005, 01:18 PM
| | Ultimas w00t! Mastah...
i have an older LG DVD-ROM and it wont read DVDRs... my friend burned me a whole bunch of stuff for school and i need it to study for exams and my rom wont read the disk...
i tried a firmware upgrade but it didnt help.. is there anything else i could try?
__________________ AMD Opteron 146 2.8ghz 280x10 1GB GEIL ONE S PC3200 DFI LanParty UT NF4 Ultra-D ATI X1800XT @ 700/800 Enermax Noisetaker 485W BigWater SE |
May 23rd, 2005, 11:28 PM
| | Human voltmeter
How is your friend burning the DVDRs? Are they + or -? Is he using UDF or ISO? What is your OS? |
May 24th, 2005, 03:49 AM
with a DVD Burner... It is a DVD+R and its just a data DVD
XP Pro is the OS |
May 24th, 2005, 06:03 AM
| | Retired mostly.
Check with nero infotool that your dvd-rom can read dvd+r. |
May 24th, 2005, 01:54 PM
| | Human voltmeter
Also try burning slower. I had a DVD-ROM that could read +R disks, but it had trouble reading the ones I burned at 8x. |
May 24th, 2005, 02:05 PM
It would be helpful to know what model DVD-ROM you have and what model DVD burner and software your friend is using to burn.
Is there so much data you can't fit onto a CD-R? |
May 24th, 2005, 03:44 PM
| Quote: |
Originally Posted by DanU Also try burning slower. I had a DVD-ROM that could read +R disks, but it had trouble reading the ones I burned at 8x. | its wierd cuz it read a DVD burned by the same friend on the same disk at the same speed... he transfered some of my vacation vids on to DVD and they work... its just the data DVDs dont work...
and yes... the data wont fit on a CDR... its a film we had to watch for marketing.. and notes and stuff... |
May 24th, 2005, 03:45 PM
| Quote: |
Originally Posted by osprey4 It would be helpful to know what model DVD-ROM you have and what model DVD burner and software your friend is using to burn.
Is there so much data you can't fit onto a CD-R? | Its an LG DVD ROM... it doesnt say the exact model..
the burner is a Lite ON 1673S |
May 24th, 2005, 04:35 PM
Are you sure he is not using a packet writing program, such as InCD, Drag to disc or Sonic DLA? |
May 24th, 2005, 05:15 PM
