Results 1 to 3 of 3
    Dec 2001
    San Diego
    970
    DMA and UDMA on same IDE channel
    I know this has been asked before, and there was a debate about it, but I couldnt find the thread So i'm going to ask it again...
    If you have a ATA100 drive as primary and a ATA33 drive as secondary, then the both are limited to ATA33 speeds right?
    Because they are capable of two different speeds, does it matter where they are on the ribbon?
    Member KenKun's Avatar
    Nov 2001
    Tokyo-Japan
    3,952
    Hi dude
    I`m not sure if this is the one .. but check it out
    http://www.techimo.com/forum/t9338.html
    Regards
    Dec 2001
    San Diego
    970
    That was it KenKun.
